Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
My screen is broken
Hey my screens broken but it's only the glass, so can i replace only the glass or is it the hole screen?
look at the pic. link below.
and which part should i buy?
thanks people.
https://fbcdn-sphotos-h-a.akamaihd.net/h...
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Don't count on replacing just the glass. The part is cheap yes, but you will need many more tools, including a method to cure new adhesive. It is a very involved repair and if you are like me it might take a couple broken LCDs out of your first batch to get the hang of it. I have it worth my while to buy the LCD assembly with the small parts preinstalled. Makes the installation much faster and almost completely painless. A total of like 9 screws and four plugs (I unplug the battery).
Punteggio 1
1 Commento:
I agree with David. Make sure to check out the Ifixit guide before attempting, helps if it's your first time. :)
da
It's not my first time but if i Want to keep the original display is that posible?
Because if i buy a New display it's not so good quality so that's why i don't Want to buy it.
But thanks for the answer guys ;)
Punteggio 0
Aggiungi la tua risposta
Nick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 121
