Salta al contenuto principale
Toshiba Satellite M55-S1001 (Celeron M 1.6 GHz, 256 MB RAM, 60 GB HDD)
1 Domande Visualizza tutte
Why are these HDD connectors not the same?
Here is the computer connector and the hard drive. Why are they different?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your Toshiba unit uses a PATA interface for it's hard drive. Sadly, the drive you have here is a SATA based hard drive which is a newer standard.
These drives are not interchangeable as you have discovered these use very different connectors.
Punteggio 3
1 Commento:
Thank you!!!
da
Aggiungi la tua risposta
Matthew Halbert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 150
