Salta al contenuto principale
The Iconia A110 is an Android tablet released by Acer in October, 2012. It features a MicroSD slot, HDMI port, a 7" multi touchscreen display, and a 2.0-megapixel front camera.
How do I replace the battery?
Every time I plug in my tablet, it will not charge. I tried buying a new charger and that didn't change anything. I am now convinced it is the battery, but do not know how to remove it. Please help.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Risposta Più Utile
kyle, check this video even so it is for a A100, it is very very similar, and this teardown to guide you with the replacement. Hope this helps, good luck
Punteggio 3
Kyle,
Take a look at the Acer Iconia A110 battery guide. This guide should explain step-by-step on how to remove your battery. Hope this helps!
Punteggio 2
My tabet is not changing at all
Punteggio 1
Aggiungi la tua risposta
Kyle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,196
