Salta al contenuto principale
Acer Iconia A110 Battery Replacement
Cosa ti serve
  1. Acer Iconia A110 Battery Replacement, Battery: passo 1, immagine 1 di 2 Acer Iconia A110 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Battery Replacement: passo 2, immagine 1 di 3 Acer Iconia A110 Battery Replacement: passo 2, immagine 2 di 3 Acer Iconia A110 Battery Replacement: passo 2, immagine 3 di 3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Battery Replacement: passo 3, immagine 1 di 3 Acer Iconia A110 Battery Replacement: passo 3, immagine 2 di 3 Acer Iconia A110 Battery Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Andrea
Membro da: 04/14/14
757 Reputazione
5 Guide realizzate
Cal Poly, Team 3-42, Maness Spring 2014 Membro di Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Membri
5 Guide realizzate
Un commento
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 25
Tutti i Tempi: 11,311
