Salta al contenuto principale
Repair and disassembly guides for HP printers.
Problem with HP DesignJet 500 InkJet Printer
I am getting an error telling me to replace all 4 print heads. I thought it was odd that all 4 would go out at the same time. Should i replace all 4 print heads or is the problem something else? Maybe
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
"This is general problem in hp plotters..
understand the concept: If U R replaced any one of print head in good working printer, printer detects new print head & it will try to align it with others. Printer will print align page to read, while reading if its found any other print heads are poor quality or bad condition, it will say to replace them also.. Some times it may 2,3 or all.
If UR printer is trying to printing align page and reading it, definitely it will detects & displays the faulty /poor quality print heads. U have to replace it..
If UR feels its expensive, try to clean the print heads manually & try for UR luck..."
Punteggio 0
1 Commento:
I have a problems with my plotter Hp DesignJet 500 of printing not straight
da
Parti e strumenti correlati
Take a look to Reparar plotter hp designjet 500, maybe they can help you!
regards
Punteggio 0
Aggiungi la tua risposta
Dean Yang sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,959
