Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
20 Domande Visualizza tutte
My ipad wont turn on
my ipad went flat over weekend now wont turn on
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
1. Verify that the charging cable that you are using works correctly. Try it on a different device.
2. Ensure that you are using the iPad wall adapter and a charging cable that is not more than 3 feet (1 meter) long. The longer cables have too much voltage drop to provide a proper charge.
3. Let it charge I disturbed for at least 10 minutes before you try to power it on.
If none of that resolves your issue, then you either have a bad battery or a damaged charging port.
Punteggio 0
Aggiungi la tua risposta
joanne sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 203
