How to repair a water softener?
Is there a repair manual for water softener? Our's is a PRO Series E E-70.
It just cycles won't turn on, release the water.
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
this might help
The incorrect regeneration cycle of your water softener might be caused by a number of factors. This includes an inadequate supply of electricity, a power outage that resulted in an incorrect setting of the clock, and a broken timer. Replace the damaged components to make the cycle functional once more.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,234
Crystal, that is a ProFlow SA-PRO-E 70? what cycles and what won't turn on?
da oldturkey03
The tank comes on and makes a lot of noise as if the water was cycling through ; however, it never stops and water never releases.
da Crystal
Water pressure drops from time to time in the kitchen faucet or bathroom shower
da osiomesiete
