Salta al contenuto principale
Repair guides and support for water softening systems.
5 Domande Visualizza tutte
How to repair a water softener?
Is there a repair manual for water softener? Our's is a PRO Series E E-70.
It just cycles won't turn on, release the water.
Questa è una buona domanda?
Punteggio 3
3 Commenti:
Crystal, that is a ProFlow SA-PRO-E 70? what cycles and what won't turn on?
da
The tank comes on and makes a lot of noise as if the water was cycling through ; however, it never stops and water never releases.
da
Water pressure drops from time to time in the kitchen faucet or bathroom shower
da
Aggiungi un commento
2 Risposte
this might help
http://docshare01.docshare.tips/files/12...
Punteggio 0
The incorrect regeneration cycle of your water softener might be caused by a number of factors. This includes an inadequate supply of electricity, a power outage that resulted in an incorrect setting of the clock, and a broken timer. Replace the damaged components to make the cycle functional once more.
Punteggio 0
Aggiungi la tua risposta
Crystal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,234
