Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
Small component broken from the logic board
Some of the small components of the logic board of an iPhone 4S are gone. It gives problems during charging. They are pointed with an arrow on the picture. What are those? Can I solve this problem by bridge the contact points? Thanks in advance.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Gauthier Top, I marked the components in numerical order. They are a follows.
1. C293 100PF 5% 16 V NP0-C0G Capacitor
2. R153 0.00 0% 1/32W Resistor
part of BATTERY_NTC circuit
3. R61 0.00 0% 1/32W Resistor
4. C300 100PF 5% 16 V NP0-C0G Capacitor
part of BATTERY_SWI circuit
You should get away by bridging the resistors, but I would not bridge the caps. Hope this helps, good luck.
Punteggio 4
5 Commenti:
It worked. Thank you very much!
da
you are welcome. Thanks for accepting my answer.
da
where can i get those Capacitor and Resistor
da
@Rahul BJ, depends on where you are located. Mouser.com Digikey.com and many other places should have those.
da
Yes they are. The 0 value resistors are actually just jumpers.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Gauthier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 7,658
