Salta al contenuto principale
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
Battery Icon with question mark (?)
My HP touchpad is out of warranty. When I try to power it on it shows a battery icon with question mark in it. When it is connected to a charger the light flashes on the center button. I have tried all solutions posted on the web, with different button combinations, leaving it on charge for more than a day, using different cables, trying to leave it connected to a computer, etc. Everything brings back the battery icon with question mark and cannot do anything more.
Connecting to a computer with USB, makes the center button lights to flash, but cannot access the file system thru USB.
I thought changing the battery, but not sure if that will fix the issue.
Is there a way to reset to factory defaults?
Please let me know if there is anyway to fix this.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
7 Risposte
Soluzione Prescelta
Here's how to replace your DEAD battery: HP TouchPad Battery Replacement
Punteggio 6
It is more than likely not the battery, but that it is 'bricked' due to corruption of the boot-up firmware. Many people have had the issue, including myself, and resolved it by the methods at this link:
http://rootzwiki.com/topic/38786-tpdebri...
If this works for you, then thank all the people who worked to develop a solution especially 'jcsullins'!
Punteggio 2
In french the solution is here:
http://lmorel3.fr/2014/05/debrickez-votr...
Punteggio 2
my talet still has a question mark on the energy symbol i try all the website in the whole world i think.but It did'nt work. i try to charge It on the computer It did'nt work, i bought a new charger It still did'nt work. now i'm just bored at home
Punteggio 1
1 Commento:
IF you are bored, you should get a new iPad.
da
Resolve this issue...
Punteggio 0
Hello I got a LG phone and when I turned on I saw the question mark on the battery I plugged In for a hour I stayed off it I plugged in for the whole night WHAT SHOULD DO????
Punteggio 0
1 Commento:
did you ever figure this out? i have same problem email me skram84@gmail.com
da
My new stylo 5 phone has its original charger it shows a question mark when plugged in. What can I do to fix it?
Punteggio 0
Aggiungi la tua risposta
Rani sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 46,636
