Salta al contenuto principale
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Need help with F-01 error
Need help with F-01 error code...can anyone tell me why I am getting this error?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Kathy, F01 is not a valid fault code, but if it is displaying that and all the lights are flashing, the main computer has trouble communicating.The F01 can mean that the central control unit has failed. I would try to first The thing to try first enter and run a diagnostic test. If it fails to run then you wil need to replace the controlunit.there is also a chance that the Motor triac short circuited check motor (especially for corrosion on the connectors) and module connections, if it is o.k there is a possible motor fault. I am certain you tried to unplug your maching and leave it unplugged for a while to give the computer a chance to reset. To start the diagnostics mode
Close the door
Push POWER
Select the RINSE/DRAIN & SPIN cycle
Push 2nd RINSE 4times in 5 seconds
Push 2nd RINSE to advance to the next step of the test procedure
If the starting procedure fails, press STOP, the repeat the starting procedure
Hope this helps, good luck.
Punteggio 1
Preparati per le riparazioni future
Questa risposta era destinata originariamente a un'altra domanda.
This procedure does not work on a HE5T !
Punteggio 1
2 Commenti:
Mark Wheeler, never said it did.For the HE5T follow this. Power off
Hold wash temp button for 3seconds than release for 3 seconds repeat that 4 times
After the fourth time you should get the "C00" on your display. That is the start of the diagnostics mode.
Total test is approximate 10minutes. If there is an error it will be shown on the display. For multiple errors, hit wash temp to cycle through the error codes.
da
I got it to go to the C00 mode but nothing happens ?
da
Hello,
I had a similar problem with my Whirlpool dryer and made a guide that might help :
Whirlpool Duet Sport Dryer F-01 fault control board repair
Cheers
Punteggio 0
Aggiungi la tua risposta
Kathy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 7,422
