Salta al contenuto principale
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Why is my ipad not working?
It states on the screen 'ipad not backed up this ipad hasn't been backed up. Backups happen when this ipad is plugged in, locked and connected to wifi' I have done that and its still will not slide open. What should I do? Please help me. Thank you.
Questa è una buona domanda?
Punteggio 3
2 Commenti
I did who side not working
da
By now I would hope that you have purchased an Android tablet which will do all an ipad will and more but at 1/4 the price. If it breaks down, and all devices can, buy a new one. Then You still have enough left over for about 3 more before you even cover the Apple Expert repair bill.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You can try a reboot. Press and hold the 'Home" button and the "ON/OFF" button at the same time and hold them until it restarts and you see the Apple Logo appear on the screen... then you can let go of the two buttons. This should "reset" your iPad and it should work properly.
Punteggio 3
3 Commenti:
Thank you so much, it worked exactly as you said, you guys rock!
da
Awesome!!! Worked for me also. Thank you Mendykasr.
da
Some help me my YouTube is telling something went wrong tap to retry when I have my wifi on
da
I've done this before and it worked. How come it doesn't work now? I could only notice that the screen brightens then turns black again
Punteggio 0
1 Commento:
i have this problem too. screen brightens, but no boot logo. I've restored and itunes sees it. Can put it into DFU mode, recovery mode. I expect it needs a front panel and or digitizer? But How to tell?
da
My iPad shuts itself off all the time. Any solutions?
Punteggio 0
Aggiungi la tua risposta
Didi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 6,019
