Salta al contenuto principale
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
How to remove dash panel to replace Radio
Trying 2replace the cd deck. Dash seems simple to remove but the trim panel wraps round the ignition hole. How do I remove the panel without damaging it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Dee brown, check on here for a broken down service manual. the instrument cluster removal is described in the "BO" file. Hope this helps, good luck
Punteggio 1
3 Commenti:
That was exactly what I needed. Truly, truly, appreciate it. Got a few other things 2do on this car as well & this has all the answers. Thank u, oldturkey03. Ur a scholar & a gentleman
da
you are welcome :-)
da
hey I have the same problem. what do you do to unlock the clips
da
Parti e strumenti correlati
Aggiungi la tua risposta
Dee Brown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 6,887
