Salta al contenuto principale
Released Apr 2008. 7MP camera with 3X Optical Zoom.
Why my LCD screen stays blank.
My Kodak C713 LCD screen remains blank. The camera does record pictures (I've checked using a card reader). I have tried all buttons and functions and am using new AA batteries. What can I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
phil, if the camera functions without difficulty otherwise, I would think that the best start would be to replace the LCD. It is possible that the backlight on the LCD is no longer functioning.
Punteggio 1
4 Commenti:
how do u replace the light
da
Della Howard, what light?
da
I have a similar problem, I can see the backlight turned on but the image on the screen is very low, when turned on it shows a little and as the seconds go by the image becomes progressively lower and lower. The camera seems to work fine with the other functions.
da
@mrcroket same as in the original answer. This could be an LCD issue as well as a DC-DC board issue. Start with the easier fix which is the LCD and then re-evaluate.
da
Preparati per le riparazioni future
Aggiungi la tua risposta
phil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 918
