Salta al contenuto principale
Motorola Moto G Play (2021) Display Panel Replacement
Cosa ti serve
  1. Motorola Moto G Play (2021) Display Panel Replacement, Heat the left edge: passo 1, immagine 1 di 1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the left edge of the cover for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Apply a suction cup to the back cover, as close to the center of the left edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Motorola Moto G Play (2021) Display Panel Replacement, Slice the right adhesive: passo 3, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the right adhesive: passo 3, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the right adhesive: passo 3, immagine 3 di 3
    • Slide your opening pick back and forth along the left edge to slice through the adhesive.
    • Leave the pick in at the bottom left corner to prevent the adhesive from resealing.
  4. Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: passo 4, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: passo 4, immagine 2 di 2
    • Insert and slide a second opening pick to the bottom right corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
    • Repeat this process for the right and top edges of the cover.
  5. Motorola Moto G Play (2021) Display Panel Replacement, Dislodge the fingerprint reader: passo 5, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Dislodge the fingerprint reader: passo 5, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Dislodge the fingerprint reader: passo 5, immagine 3 di 3
    • The fingerprint reader is connected to the motherboard by a fragile cable. You must free it before pulling the cover off.
    • Grab and lift the bottom edge of the cover.
    • As you lift the back cover, press and unstick the fingerprint reader from it.
  6. Motorola Moto G Play (2021) Display Panel Replacement, Remove the back cover: passo 6, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Remove the back cover: passo 6, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Remove the back cover: passo 6, immagine 3 di 3
    • Grab and remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  7. Motorola Moto G Play (2021) Display Panel Replacement, Reposition the fingerprint reader: passo 7, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Reposition the fingerprint reader: passo 7, immagine 2 di 2
    • Flip the fingerprint reader to the left, away from the phone.
    • Don't fold or sharply bend the ribbon cable.
  8. Motorola Moto G Play (2021) Display Panel Replacement, Unfasten the motherboard cover: passo 8, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Unfasten the motherboard cover: passo 8, immagine 2 di 2
    • Use your Phillips screwdriver to remove the twelve 3.9 mm-long screws securing the motherboard cover.
  9. Motorola Moto G Play (2021) Display Panel Replacement, Pry the motherboard cover: passo 9, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Pry the motherboard cover: passo 9, immagine 2 di 2
    • Insert the pointed end of a spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry the cover upward until you can grab it with your fingers.
  10. Motorola Moto G Play (2021) Display Panel Replacement, Remove the motherboard cover: passo 10, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Remove the motherboard cover: passo 10, immagine 2 di 2
    • Grab the bottom edge of the motherboard cover and remove it from the frame.
  11. Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the battery: passo 11, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the battery: passo 11, immagine 2 di 2
    • Use the pointed end of your spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  12. Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the fingerprint reader: passo 12, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the fingerprint reader: passo 12, immagine 2 di 2
    • Use the pointed end of your spudger to pry and disconnect the fingerprint reader's press connector.
    • The gold arrow indicates the direction to pry from.
  13. Motorola Moto G Play (2021) Display Panel Replacement, Remove the fingerprint reader: passo 13, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Remove the fingerprint reader: passo 13, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use your fingers or tweezers to remove the fingerprint reader.
    • Be careful while handling the fragile ribbon cable.
  14. Motorola Moto G Play (2021) Display Panel Replacement, Soften the adhesive with heat: passo 14, immagine 1 di 1
    • Heat an iOpener and apply it to the left edge of the screen for about two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  15. Motorola Moto G Play (2021) Display Panel Replacement, Soften the adhesive with isopropyl alcohol: passo 15, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Soften the adhesive with isopropyl alcohol: passo 15, immagine 2 di 2
    • Additionally, you may use highly-concentrated isopropyl alcohol (over 90%) to further loosen the adhesive securing the battery.
    • Apply the isopropyl alcohol into the gaps between the sides of the battery and the frame.
  16. Motorola Moto G Play (2021) Display Panel Replacement, Reposition the graphite film: passo 16, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Reposition the graphite film: passo 16, immagine 2 di 2
    • Fold the graphite heat dispersion film toward the top of the battery.
  17. Motorola Moto G Play (2021) Display Panel Replacement, Pry the battery: passo 17, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Pry the battery: passo 17, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Pry the battery: passo 17, immagine 3 di 3
    • Place a suction handle on the center of the battery.
    • Insert an opening pick between the right edge of the battery and the frame.
    • Use a steady force to pull on the suction handle and simultaneously pry with the pick.
    • Don't use excessive force on the battery. Slow, consistent pressure is all that is required to free it from the frame.
    • Apply more heat or isopropyl alcohol if the battery readheres.
  18. Motorola Moto G Play (2021) Display Panel Replacement, Remove the battery: passo 18, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Remove the battery: passo 18, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Remove the battery: passo 18, immagine 3 di 3
    • Remove the battery from its recess.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Use this guide to install a battery with custom-cut adhesives, or use this guide to install a battery with an adhesive sheet.
  19. Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the display: passo 19, immagine 1 di 2 Motorola Moto G Play (2021) Display Panel Replacement, Disconnect the display: passo 19, immagine 2 di 2
    • Use the pointed end of your spudger to pry and disconnect the display cable's press connector.
  20. Motorola Moto G Play (2021) Display Panel Replacement, Soften the display cable's adhesive: passo 20, immagine 1 di 1
    • Heat an iOpener and apply it to the display cable for two minutes.
    • The iOpener may stick to the residue left over from the battery. Clean the surrounding surface with highly-concentrated isopropyl alcohol (over 90%) to prevent this.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  21. Motorola Moto G Play (2021) Display Panel Replacement, Loosen the display cable: passo 21, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Loosen the display cable: passo 21, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Loosen the display cable: passo 21, immagine 3 di 3
    • Grab the display cable near the connector.
    • Don't attempt to completely remove the cable.
    • Peel the cable toward the bottom of the phone until it's completely separated from the frame.
  22. Motorola Moto G Play (2021) Display Panel Replacement, Heat the bottom edge: passo 22, immagine 1 di 1
    • Heat an iOpener and apply it to the bottom of the screen for about two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage, and the exterior coating of the phone will wrinkle under high temperatures.
  23. Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: passo 23, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: passo 23, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Insert an opening pick: passo 23, immagine 3 di 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a gap between the glass and the frame.
    • If the glass does not separate, apply more heat and try again.
  24. Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: passo 24, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: passo 24, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the bottom adhesive: passo 24, immagine 3 di 3
    • Don't insert the opening pick deeper than 2 mm, as you may delaminate the display panel.
    • Slide the pick back and forth to separate the bottom edge's adhesive.
  25. Motorola Moto G Play (2021) Display Panel Replacement, Slice the left adhesive: passo 25, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the left adhesive: passo 25, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement, Slice the left adhesive: passo 25, immagine 3 di 3
    • Slide your opening pick to the top left corner to separate the left edge's adhesive.
    • Repeat this process for the top and right edges to completely separate the display panel from the frame.
  26. Motorola Moto G Play (2021) Display Panel Replacement: passo 26, immagine 1 di 3 Motorola Moto G Play (2021) Display Panel Replacement: passo 26, immagine 2 di 3 Motorola Moto G Play (2021) Display Panel Replacement: passo 26, immagine 3 di 3
    • Grab and pull the bottom of the display panel down and away from the frame, making sure to thread the display cable through its slot.
    • Once the display cable is free, remove the panel from the frame.
Conclusione
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Altre 2 persone hanno completato questa guida.
Clay Eickemeyer
Membro da: 09/19/22
67.339 Reputazione
453 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.430 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 47
Tutti i Tempi: 1,105
