Introduzione
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken or malfunctioning screen on your Google Pixel 9.
If your screen doesn't come with adhesive pre‑installed, you'll need replacement screen adhesive to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the rear cover adhesive.
Cosa ti serve
Unplug all cables from your phone.
Completely power off your phone.
Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
Use a hair dryer, heat gun, or hot plate to heat the entire screen until it's almost too hot to touch.
Apply a suction handle to the center of the screen's top edge.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
Insert the tip of an opening pick under the screen.
Slide the opening pick along the top edge to separate the adhesive securing it.
Flip the screen over the right edge of your phone and prop it up with the suction handle.
Use angled tweezers to pry up the top edge of the screen cable bracket.
Remove the bracket.
Insert the point of a spudger under the left edge of the screen cable press connector and pry up to disconnect it.
Remove the screen.
When handling your screen, grip it by its edges.
When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
Use a spudger to scrape up and remove all the old screen adhesive from the perimeter of the frame.
Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
Allow the frame to dry completely before continuing.
Before applying the adhesive, make sure you know its proper orientation on the frame. Hold the adhesive over your phone to find its proper alignment.
The adhesive has a corresponding groove on the perimeter of the frame.
Cutouts in the blue liner correspond to spring contacts on the frame.
Peel down the top half of the larger, clear liner to expose the adhesive—don't remove the whole liner yet.
Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
Carefully lay your replacement screen display‑side‑down just to the right of your phone so you can reconnect the cable.
Align the screen press connector over its socket and gently press down on one side until it clicks into place, then press down on the other side.
Hook the bottom edge of the screen cable bracket into its cutout and firmly press down on the top edge until the bracket clicks into place.
Leave the perimeter display adhesive liners in place for now.
Thoroughly check your replacement screen for any small plastic liners (specifically near the front facing camera and screen cable) and use your fingers to remove them—you can identify the liners by their plastic pull tabs.
Use tweezers or your fingers to remove the two remaining blue liners from the underside of the screen.
Skip the next step.
Congratulations on completing your screen repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
Altre 14 persone hanno completato questa guida.
8Commenti sulla guida
I made this repair last night and while I think your guide is substantially complete, there is a very significant detail omitted- the replacement screen from ifixit comes with tape over the front camera glass. I assembled my phone this way, turned it on, and the front camera didn't work. I removed the new screen, removed the cover over the glass, and put it all back together, and damaged the brand new screen upon removal. I basically paid $215 to trade the cracked screen for one that has significant portions of the screen that do not work now. It's really heartbreaking that this step is not outlined in the repair, because now I have to decide if I spend ANOTHER $210 to put on a screen that works, or just deal with a brand new, broken phone, that's just broken in a different way.
Hi Travis. I'm sorry to hear about the damaged new screen and frustrating process of figuring that out. Is the tape you're talking about different from the tape the guide says to remove in step 24?
Bonjour, j'ai reçu pour mon pixel 7 et les outils une poche noir avec un liquide dedans, je l'ai ouvert ne ça ne ressemble à rien de fonctionnelle , quelle est sont utilité.
Merci
Eric Fragnol
Merci
ERIC FRAGNOL
The repair worked for me. Display is now working again. The guide says that I have to calibrate the fingerprint sensor with the Google Update and Repair Tool. But this step fails with the message: "Couldn't find the unique calibration software for this device". Any suggestions on this? Driver for the Pixel is installed and USB-Debugging is activated.
