Salta al contenuto principale
Google Pixel 9 Pro Front Facing Camera Replacement
Cosa ti serve
  1. Google Pixel 9 Pro Front Facing Camera Replacement, Safety precautions: passo 1, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 9 Pro Front Facing Camera Replacement, Adhesive information: passo 2, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Adhesive information: passo 2, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Adhesive information: passo 2, immagine 3 di 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 9 Pro Front Facing Camera Replacement, Apply a suction handle: passo 3, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Apply a suction handle: passo 3, immagine 2 di 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 9 Pro Front Facing Camera Replacement, Insert an opening pick: passo 4, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Insert an opening pick: passo 4, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Insert an opening pick: passo 4, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 9 Pro Front Facing Camera Replacement, Separate the rear cover adhesive: passo 5, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Separate the rear cover adhesive: passo 5, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Separate the rear cover adhesive: passo 5, immagine 3 di 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 9 Pro Front Facing Camera Replacement: passo 6, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement: passo 6, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement: passo 6, immagine 3 di 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 9 Pro Front Facing Camera Replacement: passo 7, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement: passo 7, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement: passo 7, immagine 3 di 3
    • Slide your pick down the right edge to separate the remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 9 Pro Front Facing Camera Replacement, Prop up the rear cover: passo 8, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Prop up the rear cover: passo 8, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Prop up the rear cover: passo 8, immagine 3 di 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the wireless charging assembly: passo 9, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the wireless charging assembly: passo 9, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    FixMat
    $31.41
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 9 Pro Front Facing Camera Replacement: passo 10, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement: passo 10, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement: passo 10, immagine 3 di 3
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the rear cover: passo 11, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the rear cover: passo 11, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the rear cover: passo 11, immagine 3 di 3
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the rear cover: passo 12, immagine 1 di 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the cable cover: passo 13, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the cable cover: passo 13, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
    • One 2.3 mm‑long screw
    • One 5.4 mm‑long screw
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 9 Pro Front Facing Camera Replacement: passo 14, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement: passo 14, immagine 2 di 2
    • Use tweezers or your fingers to remove the cable cover.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the battery: passo 15, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the battery: passo 15, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the battery: passo 15, immagine 3 di 3
    • Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave cover screw: passo 16, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave cover screw: passo 16, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the mmWave antenna cover.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 9 Pro Front Facing Camera Replacement, Unclip the 5G mmWave cover: passo 17, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Unclip the 5G mmWave cover: passo 17, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Unclip the 5G mmWave cover: passo 17, immagine 3 di 3
    • Insert the point of a spudger under the clip near the bottom left corner of the mmWave antenna cover and pry up to unclip it.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave cover: passo 18, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave cover: passo 18, immagine 2 di 2
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: passo 19, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: passo 19, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the front facing camera: passo 20, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the front facing camera: passo 20, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna screw: passo 21, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna screw: passo 21, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna screw: passo 21, immagine 3 di 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the mmWave antenna.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna: passo 22, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna: passo 22, immagine 2 di 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the front facing camera: passo 23, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the front facing camera: passo 23, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the front facing camera: passo 23, immagine 3 di 3
    • Light adhesive secures the front facing camera in place.
    • Use the point of a spudger to lift the right edge of the front facing camera, separating its adhesive.
    • Use tweezers or your fingers to remove the camera.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 9 Pro Front Facing Camera Replacement, Apply new front camera adhesive: passo 24, immagine 1 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Apply new front camera adhesive: passo 24, immagine 2 di 3 Google Pixel 9 Pro Front Facing Camera Replacement, Apply new front camera adhesive: passo 24, immagine 3 di 3
    • Use tweezers to remove the old front facing camera adhesive from the frame.
    • Remove the larger clear liner from the front facing camera adhesive.
    • Use tweezers to carefully place the adhesive into the front facing camera recess.
    • Use a spudger to press the adhesive into place, securing it to the frame.
    • Remove the remaining blue liner from the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 9 Pro Front Facing Camera Replacement, Install your replacement front camera: passo 25, immagine 1 di 2 Google Pixel 9 Pro Front Facing Camera Replacement, Install your replacement front camera: passo 25, immagine 2 di 2
    • Remove any protective caps or liners from your replacement front facing camera.
    • With the cable on the right edge, press the front facing camera into its recess to secure it with the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membro da: 09/14/22
191.474 Reputazione
1.204 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.948 guide realizzate
1Commento della guida
Por favor me podrían indicar el nombre y número de referencia del ic que controla la cámara delantera, gracias
james patiño - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 18
Ultimi 30 giorni: 100
Tutti i Tempi: 1,475
