Salta al contenuto principale
Google Pixel 8 Pro Loudspeaker Replacement
Cosa ti serve
  1. Google Pixel 8 Pro Loudspeaker Replacement, Prepare your Pixel for disassembly: passo 1, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Prepare your Pixel for disassembly: passo 1, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Prepare your Pixel for disassembly: passo 1, immagine 3 di 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 8 Pro Loudspeaker Replacement, Mark your opening picks: passo 2, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Mark your opening picks: passo 2, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Mark your opening picks: passo 2, immagine 3 di 3
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 8 Pro Loudspeaker Replacement, Tape over a cracked screen: passo 3, immagine 1 di 2 Google Pixel 8 Pro Loudspeaker Replacement, Tape over a cracked screen: passo 3, immagine 2 di 2
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 8 Pro Loudspeaker Replacement, Heat the bottom edge adhesive: passo 4, immagine 1 di 1
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 8 Pro Loudspeaker Replacement, Secure the Anti-Clamp: passo 5, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Secure the Anti-Clamp: passo 5, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Secure the Anti-Clamp: passo 5, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 8 Pro Loudspeaker Replacement, Twist the handle: passo 6, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Twist the handle: passo 6, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Twist the handle: passo 6, immagine 3 di 3
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 8 Pro Loudspeaker Replacement, Insert an opening pick: passo 7, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Insert an opening pick: passo 7, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Insert an opening pick: passo 7, immagine 3 di 3
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 8 Pro Loudspeaker Replacement, Apply a suction cup: passo 8, immagine 1 di 2 Google Pixel 8 Pro Loudspeaker Replacement, Apply a suction cup: passo 8, immagine 2 di 2
    • Apply a suction handle to the center of the screen's bottom edge.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 8 Pro Loudspeaker Replacement, Insert an opening pick: passo 9, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Insert an opening pick: passo 9, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Insert an opening pick: passo 9, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 8 Pro Loudspeaker Replacement, Prevent damage to your phone: passo 10, immagine 1 di 2 Google Pixel 8 Pro Loudspeaker Replacement, Prevent damage to your phone: passo 10, immagine 2 di 2
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 8 Pro Loudspeaker Replacement, Separate the bottom edge adhesive: passo 11, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Separate the bottom edge adhesive: passo 11, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Separate the bottom edge adhesive: passo 11, immagine 3 di 3
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 8 Pro Loudspeaker Replacement, Heat the right edge adhesive: passo 12, immagine 1 di 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 8 Pro Loudspeaker Replacement, Separate the right edge adhesive: passo 13, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Separate the right edge adhesive: passo 13, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Separate the right edge adhesive: passo 13, immagine 3 di 3
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 8 Pro Loudspeaker Replacement, Leave a pick in the bottom left corner: passo 14, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Leave a pick in the bottom left corner: passo 14, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Leave a pick in the bottom left corner: passo 14, immagine 3 di 3
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 8 Pro Loudspeaker Replacement, Heat the left edge adhesive: passo 15, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 8 Pro Loudspeaker Replacement, Separate the left edge adhesive: passo 16, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Separate the left edge adhesive: passo 16, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Separate the left edge adhesive: passo 16, immagine 3 di 3
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 8 Pro Loudspeaker Replacement, Heat the top edge adhesive: passo 17, immagine 1 di 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 8 Pro Loudspeaker Replacement, Separate the top edge adhesive: passo 18, immagine 1 di 2 Google Pixel 8 Pro Loudspeaker Replacement, Separate the top edge adhesive: passo 18, immagine 2 di 2
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 8 Pro Loudspeaker Replacement, Prop up the screen: passo 19, immagine 1 di 2 Google Pixel 8 Pro Loudspeaker Replacement, Prop up the screen: passo 19, immagine 2 di 2
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable without straining it.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 8 Pro Loudspeaker Replacement, Remove the screen cable cover: passo 20, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Remove the screen cable cover: passo 20, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Remove the screen cable cover: passo 20, immagine 3 di 3
    • Use an opening tool to pry up the upper edge of the screen cable cover.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 8 Pro Loudspeaker Replacement, Disconnect the screen: passo 21, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Disconnect the screen: passo 21, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Disconnect the screen: passo 21, immagine 3 di 3
    • Insert the point of a spudger under the top right corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 8 Pro Loudspeaker Replacement, Screen information: passo 22, immagine 1 di 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 8 Pro Loudspeaker Replacement, Reassembly information: passo 23, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Reassembly information: passo 23, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Reassembly information: passo 23, immagine 3 di 3
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Thoroughly check the entire screen for any plastic liners or tape and use the pull tabs to remove all of them. Look carefully for a large piece of plastic covering the back of the screen, a small one near the front camera cutout, and adhesive liners around the perimeter.
    • Reconnect the screen cable and reinstall its cover.
    • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 8 Pro Loudspeaker Replacement, Move the USB‑C cover tape: passo 24, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Move the USB‑C cover tape: passo 24, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Move the USB‑C cover tape: passo 24, immagine 3 di 3
    • Use the tip of a spudger to gently lift the plastic shim that runs along the top of the USB-C port cover.
    • Remove the shim and set it aside or move it out of the way so you can access the USB-C port cover screws.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 8 Pro Loudspeaker Replacement, Reassembly information: passo 25, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Reassembly information: passo 25, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Reassembly information: passo 25, immagine 3 di 3
    • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
    • Remove the larger rectangular liner from the shim.
    • Place the shim so the smaller piece of foam lines up with the bottom of the USB-C port cover.
    • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
    • Remove the remaining liner.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 8 Pro Loudspeaker Replacement, Remove the USB‑C port cover: passo 26, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Remove the USB‑C port cover: passo 26, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Remove the USB‑C port cover: passo 26, immagine 3 di 3
    FixMat
    $31.41
    • While the Pixel 8 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port cover.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 8 Pro Loudspeaker Replacement, Unfasten the speaker: passo 27, immagine 1 di 2 Google Pixel 8 Pro Loudspeaker Replacement, Unfasten the speaker: passo 27, immagine 2 di 2
    • Use a T3 Torx screwdriver to remove the 5 mm‑long 3IP Torx Plus screw securing the loudspeaker.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 8 Pro Loudspeaker Replacement, Remove the loudspeaker: passo 28, immagine 1 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Remove the loudspeaker: passo 28, immagine 2 di 3 Google Pixel 8 Pro Loudspeaker Replacement, Remove the loudspeaker: passo 28, immagine 3 di 3
    • Insert the point of a spudger between the bottom right edge of the loudspeaker and frame.
    • Pry the loudspeaker up with the spudger to dislodge it from its recess.
    • Remove the loudspeaker.
    • During reassembly, insert the edge of the speaker with an orange gasket at a downward angle into its recess. Then press the speaker firmly into place.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membro da: 09/14/22
191.306 Reputazione
1.204 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 43
Ultimi 30 giorni: 156
Tutti i Tempi: 4,587
