Salta al contenuto principale
Google Pixel 8 Logic Board Replacement
Cosa ti serve
  1. Google Pixel 8 Logic Board Replacement, Prepare your Pixel for disassembly: passo 1, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Prepare your Pixel for disassembly: passo 1, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Prepare your Pixel for disassembly: passo 1, immagine 3 di 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 8 Logic Board Replacement, Remove the SIM card tray: passo 2, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the SIM card tray: passo 2, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the SIM card tray: passo 2, immagine 3 di 3
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 8 Logic Board Replacement, Mark your opening picks: passo 3, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Mark your opening picks: passo 3, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Mark your opening picks: passo 3, immagine 3 di 3
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 8 Logic Board Replacement, Heat the bottom edge adhesive: passo 4, immagine 1 di 1
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 8 Logic Board Replacement, Secure the Anti-Clamp: passo 5, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Secure the Anti-Clamp: passo 5, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Secure the Anti-Clamp: passo 5, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 8 Logic Board Replacement, Twist the handle: passo 6, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Twist the handle: passo 6, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Twist the handle: passo 6, immagine 3 di 3
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 8 Logic Board Replacement, Insert an opening pick: passo 7, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Insert an opening pick: passo 7, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Insert an opening pick: passo 7, immagine 3 di 3
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 8 Logic Board Replacement, Apply a suction cup: passo 8, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Apply a suction cup: passo 8, immagine 2 di 2
    • Apply a suction handle to the center of the screen's bottom edge.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 8 Logic Board Replacement, Insert an opening pick: passo 9, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Insert an opening pick: passo 9, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Insert an opening pick: passo 9, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 8 Logic Board Replacement, Prevent damage to your phone: passo 10, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Prevent damage to your phone: passo 10, immagine 2 di 2
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 8 Logic Board Replacement, Separate the bottom edge adhesive: passo 11, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Separate the bottom edge adhesive: passo 11, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Separate the bottom edge adhesive: passo 11, immagine 3 di 3
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 8 Logic Board Replacement, Heat the right edge adhesive: passo 12, immagine 1 di 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 8 Logic Board Replacement, Separate the right edge adhesive: passo 13, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Separate the right edge adhesive: passo 13, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Separate the right edge adhesive: passo 13, immagine 3 di 3
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 8 Logic Board Replacement, Leave a pick in the bottom left corner: passo 14, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Leave a pick in the bottom left corner: passo 14, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Leave a pick in the bottom left corner: passo 14, immagine 3 di 3
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 8 Logic Board Replacement, Heat the left edge adhesive: passo 15, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 8 Logic Board Replacement, Separate the left edge adhesive: passo 16, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Separate the left edge adhesive: passo 16, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Separate the left edge adhesive: passo 16, immagine 3 di 3
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 8 Logic Board Replacement, Heat the top edge adhesive: passo 17, immagine 1 di 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 8 Logic Board Replacement, Separate the top edge adhesive: passo 18, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Separate the top edge adhesive: passo 18, immagine 2 di 2
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 8 Logic Board Replacement, Prop up the screen: passo 19, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Prop up the screen: passo 19, immagine 2 di 2
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • Be careful not to strain the screen cable.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 8 Logic Board Replacement, Remove the screen cable cover: passo 20, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the screen cable cover: passo 20, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the screen cable cover: passo 20, immagine 3 di 3
    • Use an opening pick to pry up the upper edge of the screen cable cover.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 8 Logic Board Replacement, Disconnect the screen: passo 21, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Disconnect the screen: passo 21, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Disconnect the screen: passo 21, immagine 3 di 3
    • Insert the point of a spudger under the top left corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 8 Logic Board Replacement, Screen information: passo 22, immagine 1 di 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 8 Logic Board Replacement, Reassembly information: passo 23, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Reassembly information: passo 23, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Reassembly information: passo 23, immagine 3 di 3
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Use the pull tabs to remove the liners covering the front camera cutout, the rear camera pad, the back of the screen, and the perimeter adhesive.
    • Reconnect the screen cable and reinstall its cover.
    • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
    • Firmly press the screen into place on the frame. You should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 8 Logic Board Replacement, Remove the shim: passo 24, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the shim: passo 24, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the shim: passo 24, immagine 3 di 3
    • A plastic shim is lightly adhered to the midframe and bottom speaker.
    • Slide the tip of an opening pick under the plastic shim until you can grip it with tweezers or your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 8 Logic Board Replacement: passo 25, immagine 1 di 3 Google Pixel 8 Logic Board Replacement: passo 25, immagine 2 di 3 Google Pixel 8 Logic Board Replacement: passo 25, immagine 3 di 3
    • Use tweezers, or your fingers, to peel off and remove the shim from the midframe and the bottom speaker.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 8 Logic Board Replacement, Unfasten the USB-C port bracket: passo 26, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Unfasten the USB-C port bracket: passo 26, immagine 2 di 2
    FixMat
    $31.41
    • While the Pixel 8 uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx driver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port bracket.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 8 Logic Board Replacement, Remove the USB-C port bracket: passo 27, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Remove the USB-C port bracket: passo 27, immagine 2 di 2
    • Use tweezers, or your fingers, to remove the USB-C port bracket.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 8 Logic Board Replacement, Reassembly information: passo 28, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Reassembly information: passo 28, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Reassembly information: passo 28, immagine 3 di 3
    • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
    • Remove the clear liner from the shim.
    • Use the markings on the midframe to align the left side of the shim and press it into place.
    • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
    • Remove the blue liner.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel 8 Logic Board Replacement, Unfasten the bottom speaker: passo 29, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Unfasten the bottom speaker: passo 29, immagine 2 di 2
    • Use a T3 Torx driver to remove the 5 mm‑long screw securing the bottom speaker.
    Chiedi a FixBot
    Aggiungi Commento
  30. Google Pixel 8 Logic Board Replacement, Remove the bottom speaker: passo 30, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the bottom speaker: passo 30, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the bottom speaker: passo 30, immagine 3 di 3
    • Insert the point of a spudger between the top right corner of the bottom speaker and the frame.
    • Pry the bottom speaker up with the spudger to dislodge it from its recess.
    • Remove the bottom speaker.
    • During reassembly, insert the edge of the speaker with an black gasket at a downward angle into its recess. Then press the speaker firmly into place.
    Chiedi a FixBot
    Aggiungi Commento
  31. Google Pixel 8 Logic Board Replacement, Disconnect the 5G mmWave antenna: passo 31, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Disconnect the 5G mmWave antenna: passo 31, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Disconnect the 5G mmWave antenna: passo 31, immagine 3 di 3
    • Use the point of the spudger to pry up and disconnect the 5G mmWave antenna cable from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  32. Google Pixel 8 Logic Board Replacement, Heat the 5G mmWave antenna cable: passo 32, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Heat the 5G mmWave antenna cable: passo 32, immagine 2 di 2
    • The 5G mmWave antenna cable is secured to the midframe with adhesive in two places.
    • Heat an iOpener and lay it on the left edge of the phone for two minutes to soften the cable adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as, extreme heat can damage the battery.
    Chiedi a FixBot
    Aggiungi Commento
  33. Google Pixel 8 Logic Board Replacement, Separate the adhesive: passo 33, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Separate the adhesive: passo 33, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Separate the adhesive: passo 33, immagine 3 di 3
    • Insert an opening pick under the 5G mmWave antenna cable's bottom section of adhesive.
    • Slide the pick toward the top edge of the phone to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  34. Google Pixel 8 Logic Board Replacement: passo 34, immagine 1 di 2 Google Pixel 8 Logic Board Replacement: passo 34, immagine 2 di 2
    • Repeat the previous step for the upper section of adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  35. Google Pixel 8 Logic Board Replacement, Reposition the 5G mmWave antenna cable: passo 35, immagine 1 di 1
    • Move the 5G mmWave antenna cable over the top of the phone to keep it out of the way.
    • Don't fold or crease the cable—just move it enough so it doesn't interfere with disassembly.
    Chiedi a FixBot
    Aggiungi Commento
  36. Google Pixel 8 Logic Board Replacement, Remove the graphite sheet: passo 36, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the graphite sheet: passo 36, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the graphite sheet: passo 36, immagine 3 di 3
    • A large graphite sheet must be removed and replaced to complete this repair. It connects the upper part of the battery, midframe, and the rear cameras.
    • Insert the point of a spudger under the top right corner of the graphite sheet and lift until you can grip the sheet with your fingers.
    • Peel up and remove the entire graphite sheet.
    • If your sheet tears, don't worry! Grip the torn parts and remove the sheet in sections.
    • During reassembly, do not reuse the old graphite sheet. Follow this guide to replace the sheet.
    Chiedi a FixBot
    Aggiungi Commento
  37. Google Pixel 8 Logic Board Replacement, Unfasten the midframe: passo 37, immagine 1 di 1
    • Use a T3 Torx screwdriver to remove the eight 5.1 mm‑long 3IP Torx Plus screws securing the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  38. Google Pixel 8 Logic Board Replacement, Remove the midframe: passo 38, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the midframe: passo 38, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the midframe: passo 38, immagine 3 di 3
    • The center of the midframe is lightly bonded to a thermal pad.
    • Slide the flat end of a spudger under the bottom right corner of the midframe to separate it from the thermal pad.
    • You'll feel the midframe loosen once it separates completely.
    Chiedi a FixBot
    Aggiungi Commento
  39. Google Pixel 8 Logic Board Replacement: passo 39, immagine 1 di 3 Google Pixel 8 Logic Board Replacement: passo 39, immagine 2 di 3 Google Pixel 8 Logic Board Replacement: passo 39, immagine 3 di 3
    • Lift the midframe off the frame and remove it.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
    Chiedi a FixBot
    Aggiungi Commento
  40. Google Pixel 8 Logic Board Replacement, Disconnect the battery: passo 40, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Disconnect the battery: passo 40, immagine 2 di 2
    • Use a spudger to pry up and disconnect the battery connector.
    Chiedi a FixBot
    Aggiungi Commento
  41. Google Pixel 8 Logic Board Replacement, Disconnect the wide rear camera: passo 41, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Disconnect the wide rear camera: passo 41, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Disconnect the wide rear camera: passo 41, immagine 3 di 3
    • Insert the point of a spudger under the bottom half of the wide rear camera press connector, between the surface-mounted components.
    • Don't insert your pick anywhere else, as you risk damaging the logic board.
    • Pry up to disconnect the wide rear camera.
    Chiedi a FixBot
    Aggiungi Commento
  42. Google Pixel 8 Logic Board Replacement, Unfasten the wide rear camera: passo 42, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Unfasten the wide rear camera: passo 42, immagine 2 di 2
    • Use a T3 Torx screwdriver to remove the two 5.1 mm‑long 3IP Torx Plus screws securing the wide rear camera.
    Chiedi a FixBot
    Aggiungi Commento
  43. Google Pixel 8 Logic Board Replacement, Remove the wide rear camera: passo 43, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the wide rear camera: passo 43, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the wide rear camera: passo 43, immagine 3 di 3
    • Insert the tip of a spudger under one of the wide rear camera screw hole cutouts.
    • Use the spudger to lift the camera out of its recess.
    • Remove the camera.
    Chiedi a FixBot
    Aggiungi Commento
  44. Google Pixel 8 Logic Board Replacement, Disconnect the ultrawide rear camera: passo 44, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Disconnect the ultrawide rear camera: passo 44, immagine 2 di 2
    • Use a spudger to pry up and disconnect the ultrawide rear camera press connector from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  45. Google Pixel 8 Logic Board Replacement, Remove the ultrawide rear camera: passo 45, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the ultrawide rear camera: passo 45, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the ultrawide rear camera: passo 45, immagine 3 di 3
    • Insert the tip of a spudger under the top screw cutout on the ultrawide rear camera.
    Chiedi a FixBot
    Aggiungi Commento
  46. Google Pixel 8 Logic Board Replacement, Disconnect the front camera: passo 46, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Disconnect the front camera: passo 46, immagine 2 di 2
    • Use a spudger to pry up and disconnect the front camera press connector from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  47. Google Pixel 8 Logic Board Replacement, Separate the adhesive: passo 47, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Separate the adhesive: passo 47, immagine 2 di 2
    Tesa 61395 Tape
    $8.95
    • The front camera cable is lightly adhered to the earpiece speaker.
    • Slide an opening pick under the front camera cable to separate the adhesive.
    • During reassembly, reuse your old adhesive if it's still sticky. If not, use a double-sided tape like Tesa Tape to resecure the front camera.
    Chiedi a FixBot
    Aggiungi Commento
  48. Google Pixel 8 Logic Board Replacement, Remove the front camera: passo 48, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the front camera: passo 48, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the front camera: passo 48, immagine 3 di 3
    • The 5G mmWave antenna cable overlaps the bottom edge of the front camera.
    • Move the antenna cable toward the right edge of the phone to free the front camera.
    • Remove the front camera.
    • During reassembly, make sure the front camera rests properly in its recess and under the antenna cable.
    Chiedi a FixBot
    Aggiungi Commento
  49. Google Pixel 8 Logic Board Replacement, Unfasten the 5G mmWave antenna bracket: passo 49, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Unfasten the 5G mmWave antenna bracket: passo 49, immagine 2 di 2
    • Use a T3 Torx screwdriver to remove the 5.1 mm‑long 3IP Torx Plus screw securing the 5G mmWave antenna bracket.
    Chiedi a FixBot
    Aggiungi Commento
  50. Google Pixel 8 Logic Board Replacement, Remove the bracket: passo 50, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the bracket: passo 50, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the bracket: passo 50, immagine 3 di 3
    • Insert the point of a spudger in the notch at the top right corner of the 5G mmWave antenna bracket.
    • Pry up with the spudger to separate the bracket from its recess in the frame.
    • Remove the bracket.
    • During reassembly, reinsert the top edge of the bracket first at a downward angle so its foam pad sits properly before resecuring the bracket.
    Chiedi a FixBot
    Aggiungi Commento
  51. Google Pixel 8 Logic Board Replacement, Remove the antenna: passo 51, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the antenna: passo 51, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the antenna: passo 51, immagine 3 di 3
    • Pull the antenna and its cable out of the frame and remove it.
    • If your cable disconnects from the antenna, don't worry! Align the cable press connector over its socket and press down with your fingers until it snaps into place.
    Chiedi a FixBot
    Aggiungi Commento
  52. Google Pixel 8 Logic Board Replacement, Disconnect the interconnect cable: passo 52, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Disconnect the interconnect cable: passo 52, immagine 2 di 2
    • Use a spudger to pry up and disconnect the interconnect cable press connector.
    Chiedi a FixBot
    Aggiungi Commento
  53. Google Pixel 8 Logic Board Replacement: passo 53, immagine 1 di 1
    • Adhesive secures the top and bottom edges of the battery to the frame. Heating the back cover softens the adhesive, making it easier to separate.
    • Carefully flip your phone over and lay it down on your workspace.
    • Use a hairdryer or heat gun to heat the left side of the back cover, near the top and bottom edges of the battery. It should be slightly too hot to touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  54. Google Pixel 8 Logic Board Replacement, Apply isopropyl alcohol: passo 54, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Apply isopropyl alcohol: passo 54, immagine 2 di 2
    • Flip your phone back over and lay it on your workspace.
    • Apply a few drops of highly-concentrated isopropyl alcohol (>90%) along the right edge of the battery.
    Chiedi a FixBot
    Aggiungi Commento
  55. Google Pixel 8 Logic Board Replacement: passo 55, immagine 1 di 2 Google Pixel 8 Logic Board Replacement: passo 55, immagine 2 di 2
    • Tilt your phone to help the alcohol flow towards the adhesive on the top and bottom edges of the battery.
    • Wait one minute to allow the alcohol to dissolve the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  56. Google Pixel 8 Logic Board Replacement, Insert an opening pick: passo 56, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Insert an opening pick: passo 56, immagine 2 di 2
    • Insert the flat side of an opening pick between the right edge of the battery and frame.
    Chiedi a FixBot
    Aggiungi Commento
  57. Google Pixel 8 Logic Board Replacement, Separate the battery adhesive: passo 57, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Separate the battery adhesive: passo 57, immagine 2 di 2
    • Don't crease or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • The adhesive securing the battery is very strong. Separating it requires time and constant pressure. It will most likely take multiple rounds of heat and isopropyl alcohol.
    • Firmly secure your phone with one hand.
    • With your free hand, pry the battery up with the pick. Maintain constant pressure on the pick until the battery separates from the frame.
    • If after two minutes of constant pressure the battery doesn't budge, apply more heat and isopropyl alcohol and try again.
    Chiedi a FixBot
    Aggiungi Commento
  58. Google Pixel 8 Logic Board Replacement, Remove the battery: passo 58, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the battery: passo 58, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the battery: passo 58, immagine 3 di 3
    • If your battery is creased, bent, or deformed, do not reuse it—it's a fire hazard. Replace it with a new battery.
    • Use the opening pick to lift the battery and separate the remaining adhesive.
    • Remove the battery.
    • During reassembly, follow this guide to remove the old adhesive and install your battery.
    Chiedi a FixBot
    Aggiungi Commento
  59. Google Pixel 8 Logic Board Replacement, Unfasten the grounding bracket: passo 59, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Unfasten the grounding bracket: passo 59, immagine 2 di 2
    • Use a T3 Torx screwdriver to remove the 2.5 mm‑long 3IP Torx Plus screw securing the grounding bracket to the bottom right edge of your phone.
    Chiedi a FixBot
    Aggiungi Commento
  60. Google Pixel 8 Logic Board Replacement, Remove the grounding bracket: passo 60, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Remove the grounding bracket: passo 60, immagine 2 di 2
    • Remove the grounding bracket.
    Chiedi a FixBot
    Aggiungi Commento
  61. Google Pixel 8 Logic Board Replacement, Unfasten the logic board: passo 61, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Unfasten the logic board: passo 61, immagine 2 di 2
    • Use a T3 Torx screwdriver to remove the two 3.5 mm‑long 3IP Torx Plus screws securing the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  62. Google Pixel 8 Logic Board Replacement, Reposition the interconnect cable: passo 62, immagine 1 di 2 Google Pixel 8 Logic Board Replacement, Reposition the interconnect cable: passo 62, immagine 2 di 2
    • Move the interconnect cable away from the frame to keep it from snagging on the logic board.
    • Optionally, you can tape the cable to the left edge of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  63. Google Pixel 8 Logic Board Replacement, Remove the logic board: passo 63, immagine 1 di 3 Google Pixel 8 Logic Board Replacement, Remove the logic board: passo 63, immagine 2 di 3 Google Pixel 8 Logic Board Replacement, Remove the logic board: passo 63, immagine 3 di 3
    • Before removing the logic board, make sure the SIM card tray is removed.
    • Use the flat end of a spudger to lift the top edge of the logic board until you can grip it with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  64. Google Pixel 8 Logic Board Replacement: passo 64, immagine 1 di 3 Google Pixel 8 Logic Board Replacement: passo 64, immagine 2 di 3 Google Pixel 8 Logic Board Replacement: passo 64, immagine 3 di 3
    • Lift the top of the logic board upward to release its bottom clip.
    • Remove the logic board.
    • During reassembly, reinsert the USB-C port at a downward angle and align the rubber gasket before pressing the logic board into place.
    Chiedi a FixBot
    Aggiungi Commento
  65. Google Pixel 8 Logic Board Replacement: passo 65, immagine 1 di 2 Google Pixel 8 Logic Board Replacement: passo 65, immagine 2 di 2
    • If your rubber plunger next to the SIM card tray slot fell out, reinsert it with the red rings facing the outer edge of the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 8 Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
239.274 Reputazione
1.171 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 79
Ultimi 30 giorni: 340
Tutti i Tempi: 9,320
