Salta al contenuto principale
iPod Touch 2nd Generation Power/Volume Controls Replacement
Walter Galan
Walter Galan e 4 altri collaboratori
Ultimo aggiornamento il 1 ago 2022
2 ore
Difficile
Introduzione
Vai al passo 1
Replace the power/volume controls to awaken an unresponsive Touch.
Cosa ti serve
Strumenti
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Mostra di più…
  1. iPod Touch 2nd Generation Power/Volume Controls Replacement, Front Panel: passo 1, immagine 1 di 1
    • The glass front panel on the second generation Touch has a plastic frame glued both to its outer edge and also under the wide black strips at the top and bottom of the device. The frame also has a rubber strip that surrounds the edge of the glass panel.
    • The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
    • Also, be mindful of the very thin and delicate touch screen ribbon cable (connector location shown in orange) attaching the front panel to the upper left corner of the Touch.
  2. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 2, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 2, immagine 2 di 2
    • Gently insert a plastic opening tool, near the volume control buttons, between the plastic surround of the screen and the metal case.
    • Rotate the tool away from the Touch to pry up on the glass panel.
    • The key is to work slowly and gently to avoid breaking internal components.
    • If you are having difficulties using a plastic opening tool. You could try a razor blade, we found it easier to release the clips with one. Please be extremely careful if you take this route!
    If you are planning on reusing the front bezel / seal around the glass screen, be careful not to rip it up too much when loosening the screen.
    iTronics Repair - Replica
    If you bought a new front panel there is a rubber seal around it so dont worry about ripping it up to open your iPod
    mikeseptak - Replica
    Citazione da mikeseptak:
    sometimes if you buy a new front it doesn't come with the front bezel, so make sure it does before you rip the old one up. otherwise you can get a new front bezel from ebay.
    "Gently insert an iPod opening tool between the glass front panel and its plastic surround near the headphone jack."
    My guess is near the "Volume Control" not the "headphone jack" since the Headphone is oriented at the bottom of the picture not where the tool is being shown.
    barlowdo - Replica
    Cracked the glass dropping on tile floor. I used a metal guitar pick to remove the glass/digitizer/bezel/"o" ring assembly, noting the clips in the first picture, I worked my way around and between the clips - starting at the volume control - first to loosen the glass/digitizer, then to go deeper and vertically lift the bezel and free the bezel from the clips. As others say - if you purchase from this site DO NOT worry about the bezel OR the "o" ring around the bezel - just get the entire thang out and the new one slips/snaps into place with ease - entire process took about 10min for removal and 3 for replacement - and I HAVE A NEW WORKING iPod TOUCH!! Jerry -Houston, TX - 281-687-2755 for questions...
    jgreengold - Replica
    And the service and shipping are excellent - and now I'm gonna buy a new MacBook keyboard from this company and fix my daughters stuck "z" key - I love IFIXIT - would recommend to ALL - products and instructions are EXCELLENT - yes ebay *may* be cheaper but you get what you pay for... HIGHLY RECOMMEND IFIXIT...
    Citazione da jgreengold:
    I am not familiar with a Metal Guitar pick, The plastic ones break very easily. (Even my Fender one) Did your metal pick damage the metal frame of your iPod? Were you able to remove the touch screen, o-ring, and plastic bezel without further damage to the parts?
    When I attempted to use a metal screwdriver I damaged the LCD.
    barlowdo - Replica
    Citazione da barlowdo:
    I am not familiar with a Metal Guitar pick, The plastic ones break very easily. (Even my Fender one) Did your metal pick damage the metal frame of your iPod? Were you able to remove the touch screen, o-ring, and plastic bezel without further damage to the parts? When I attempted to use a metal screwdriver I damaged the LCD.
    Not too hard to find - either at music store a sometimes as a jewelry
    "charm"... Mine is the latter - very thin, very stiff. It did not damage
    the frame of the iPod at all. However - after replacing the new part I noted
    a plastic protector sheet on the *underside* of the new screen - upon
    removing the new top glass panel using the same guitar pick a second time, I
    too damaged the LCD - I also damaged the bezel and O ring. The O ring is
    very difficult to get off in a reusable condition. The bezel can come off
    clean with patience - which I apparently have little of and hence purchased
    a second glass top assembly to go along with the new LCD. I think the key
    here is patience and very slow going - I also purchased an iPod opening tool
    as another key learning is that while the guitar pick does work - it tends
    to get inserted too deep damaging the bezel (separating it from the glass or
    breaking it) or damaging internal parts. But the opening tool can sometimes
    be not firm enough. I imagine with practice one can remove the entire
    assembly in completely reusable condition - the trick it seems is to
    understand that the bezel has vertical sides that must be lifted vertically
    after being unclipped from the case - and that the glass has a tendency to
    separate from the bezel...
    I tried a flathead screwdriver and cracked the front panel.I learned that prying with a flathead screwdriver will damage it.
    Honam1021 -
    Last night I recalled I use to own a metal pic it was a thumb pic for slide guitar. Anyway I decided to use my metal tools I bought from this site which are more rounded edges than the flat bladed screw driver that comes with kits. I made more progress with the metal tools and got what I think is all sides mostly up accept for the home button side which is really fighting me. I can easily tell where a clip is by sliding the tool alongside until I bump up against the side of a clip but I find it very difficult to push straight down to catch the top of the clip which it would seem would push away from the bezel. I am just not sure why this is difficult to do. I have a broken 2nd gen which I use as reference and it looks like the clip would easily push away. At any rate I am in the same predicament as you. I got the 2nd gen together only to find the home button sticks and wifi range is not what it use to be. So I am attempting to take the iPod apart a 2nd time to fix these issues without breaking the touch screen and lcd and so am taking my time. I just don't want to have to replace these brand new parts and have more money in this 8 gig 2nd gen than if I had just bought a brand new one.
    barlowdo - Replica
    Hi jgreengold, Can you help me to check if your iPod touch is like mine on this picture?: http://i44.tinypic.com/2a8ga6p.jpg
    My iPod touch bottom glass is a bit raised over the chrome bezel at the right part. Please check it and many thanks for your reply!!
    daikyouju - Replica
    best I can see my touch glass is level with the frame - whether this picture is pre or post glass replacement, you need to gently, slowly, firmly, press down to try to seat the glass better in the frame/clip. I've see cases where after removint a glass top, the removal of the bexel is not perfect and it may leavel some of the black plastic bexel in the clip which makes it impossible to then copmpletely seat the new top glass/bezel.
    Be sure to pry between the outer case and the rubber gasket and not between the gasket and the glass
    mgardner - Replica
    isn't this instruction misleading? :
    i agree with mgardner: "Be sure to pry between the outer case and the rubber gasket and not between the gasket and the glass"
    vera - Replica
    I changed the text to reflect this. It's currently the "unverified" version.
    no way -
    I tried using the razor blade since the plastic opening tool was useless. I cracked the front panel and scratched the LCD. It had moisture damage and the touchscreen wasn't working. So be very careful when you use the razorblade...
    rockon46 - Replica
  3. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 3, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 3, immagine 2 di 2
    • Insert the plastic opening tool between the front panel and its plastic surround and pry up at several points along the left edge of the Touch.
    • Do not insert the tool and run it down the edge of the front panel. This may damage the front panel and the rubber seal. It is best to work one point, pry up, then remove the tool and reinsert it at the next spot to be pried up.
  4. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 4, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 4, immagine 2 di 2
    • Continue prying up the left edge until the top and bottom edges start to lift out of the Touch.
    • Once the top and bottom edges have lifted slightly out of the Touch, use the opening tool to assure the plastic surround is detached from the clips along the inside of the Touch.
  5. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 5, immagine 1 di 1
    • Continue the prying procedure, now focusing on detaching the plastic surround from the internal metal clips.
    • Pry along the top edge of the Touch to further separate the front panel from the rest of the device.
  6. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 6, immagine 1 di 3 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 6, immagine 2 di 3 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 6, immagine 3 di 3
    • Pry up the front panel along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the front panel until it is lifted slightly from the rear panel.
    • Also, ensure that the plastic surround is separated from the clips in the rear panel.
  7. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 7, immagine 1 di 1
    • Lift the front panel out of the rear case minding the cable still attaching it near the upper left corner of the Touch.
    • Make sure you DO NOT tear the display's touch screen connector cable. Tearing this will render your display useless.
  8. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 8, immagine 1 di 1
    • Use the flat end of a spudger (or an opening tool) to pry the touch screen cable connector up off the upper logic board.
    • Now that the front panel is out, check it for damage. If the plastic surround is not flush with the front face of the glass panel, gently peel it off and stick it down.
    • Be careful not to scratch the front panel on the underside of the black portions, as the scratches will be visible once the device is reassembled.
    • Be sure to clean both the face of the display and the inner surface of the front panel, as any dust or fingerprints will be trapped inside the Touch once it is fully reassembled.
  9. iPod Touch 2nd Generation Power/Volume Controls Replacement, Display: passo 9, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement, Display: passo 9, immagine 2 di 2
    • Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
    • Pry up along the lower edge of the display enough to grab it with your fingers.
  10. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 10, immagine 1 di 1
    • Lift the display up from its lower edge and rotate it toward the top of the Touch.
    • The next few steps require removal of components under where the display normally sits. Be sure to hold the display to avoid putting tension on the delicate display ribbon cable.
  11. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 11, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 11, immagine 2 di 2
    • While holding the display with one hand, run an iPod opening tool down the two long edges of the mylar reflector attached to the metal display tray.
    • When it is sufficiently free from the display tray, remove the mylar reflector from the Touch.
  12. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 12, immagine 1 di 1
    • Remove the seven Phillips screws securing the metal display tray to the rear panel.
    • The two darker screws belong in the two holes in the tray nearest the bottom edge of the Touch.
  13. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 13, immagine 1 di 1
    • Lay the display back down into its tray.
    • Remove the final Phillips screw securing the metal tray to the rear panel.
  14. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 14, immagine 1 di 1
    • Lift the display out of the metal tray and rotate it toward the top edge of the Touch.
    • Use an iPod opening tool to lift the metal display tray and rotate it up toward the top edge of the Touch.
  15. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 15, immagine 1 di 1
    • Use the edge of an iPod opening tool to peel the copper tape off the top edge of the display.
    • Leave the copper tape attached to the metal display tray.
  16. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 16, immagine 1 di 1
    • Use an iPod opening tool to pry the display cable connector up off its socket on the logic board.
  17. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 17, immagine 1 di 1
    • Lift the metal display tray slightly (the battery is attached to its underside) and remove the display from the Touch, minding its delicate cable that may get caught.
    • The display ribbon cable is routed under the metal display tray.
  18. iPod Touch 2nd Generation Power/Volume Controls Replacement, Logic Board: passo 18, immagine 1 di 1
    • Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
    • Remove the metal display tray and set it aside.
    • Lay the battery flat in the rear panel.
  19. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 19, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 19, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the single Phillips screw securing the gold pressure contact to the logic board.
    • Use a pair of tweezers to lift the Phillips screw out of the logic board.
  20. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 20, immagine 1 di 1
    • Remove the following three Phillips screws securing the logic board to the rear panel:
    • One 1.9 mm screw
    • Two 2.3 mm screws
    • The darker screw belongs in the screw hole next to the dock connector.
  21. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 21, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 21, immagine 2 di 2
    • Using the tip of a spudger, flip up the control button ribbon cable retaining flap.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • This socket is found under the battery.
  22. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 22, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 22, immagine 2 di 2
    • Use a pair of tweezers to pull the control button ribbon cable straight out of its socket.
  23. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 23, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 23, immagine 2 di 2
    • Use the tip of a spudger to peel back the protective rubber grommet to reveal a hidden Phillips screw.
    • It is not necessary to completely remove this flap.
    • Remove the hidden Phillips screw.
  24. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 24, immagine 1 di 1
    • Remove the two remaining Phillips screws securing the upper logic board to the rear panel.
  25. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 25, immagine 1 di 1
    • Use the flat end of a spudger to separate the Wi-Fi ribbon cable from the adhesive securing it to the rear panel.
  26. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 26, immagine 1 di 1
    • Insert the flat end of a spudger between the metal rear panel and Wi-Fi ribbon cable to further loosen the adhesive along the length of the cable.
  27. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 27, immagine 1 di 1
    • Use your hands to continue peeling the Wi-Fi ribbon off the rear panel.
  28. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 28, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 28, immagine 2 di 2
    • Pull the small upper portion of the logic board away from the top edge of the Touch to separate it from the rear panel.
    • Allow the board to rest on the outside of the rear panel.
  29. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 29, immagine 1 di 1
    • Gently pull the lower portion of the logic board away from the bottom edge of the rear panel.
  30. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 30, immagine 1 di 2 iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 30, immagine 2 di 2
    • Carefully lift the logic board assembly out of the rear case, minding any edges that may get caught.
  31. iPod Touch 2nd Generation Power/Volume Controls Replacement, Power/Volume Controls: passo 31, immagine 1 di 1
    • Remove the two Phillips screws securing the power/volume controls to the rear panel.
  32. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 32, immagine 1 di 1
    • Use the tip of a spudger to remove the yellow kapton tape covering the power/volume control ribbon cable.
  33. iPod Touch 2nd Generation Power/Volume Controls Replacement: passo 33, immagine 1 di 1
    • Lift the power/volume controls out of the rear panel.
  34. iPod Touch 2nd Generation Power/Volume Controls Replacement, Power/Volume Controls: passo 34, immagine 1 di 1
    • Power/Volume controls remain.
Conclusione
Altre 38 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
2Commenti sulla guida
what pins are for the on/off button on the logic board?
Josh McLaughlin - Replica
OMG this look super hard but my power button is broken
_ICraftQc_ - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 163
Tutti i Tempi: 98,327
