Salta al contenuto principale
iPhone 14 Taptic Engine Replacement
Cosa ti serve
  1. iPhone 14 Taptic Engine Replacement, Remove the pentalobe screws: passo 1, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Remove the pentalobe screws: passo 1, immagine 2 di 2
    • Power off your iPhone before beginning disassembly.
    • Use a P2 pentalobe screwdriver to remove the two 6.8 mm‑long screws on either side of the charging port.
    Chiedi a FixBot
    Aggiungi Commento
  2. iPhone 14 Taptic Engine Replacement, Mark your opening picks: passo 2, immagine 1 di 3 iPhone 14 Taptic Engine Replacement, Mark your opening picks: passo 2, immagine 2 di 3 iPhone 14 Taptic Engine Replacement, Mark your opening picks: passo 2, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  3. iPhone 14 Taptic Engine Replacement, Tape over any cracks: passo 3, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Tape over any cracks: passo 3, immagine 2 di 2
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
    Chiedi a FixBot
    Aggiungi Commento
  4. iPhone 14 Taptic Engine Replacement, Heat the bottom edge: passo 4, immagine 1 di 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the rear glass is slightly too hot to touch.
    • Never leave your heat gun in one spot for an extended period of time.
    Chiedi a FixBot
    Aggiungi Commento
  5. iPhone 14 Taptic Engine Replacement, Insert an opening pick: passo 5, immagine 1 di 3 iPhone 14 Taptic Engine Replacement, Insert an opening pick: passo 5, immagine 2 di 3 iPhone 14 Taptic Engine Replacement, Insert an opening pick: passo 5, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
    Chiedi a FixBot
    Aggiungi Commento
  6. iPhone 14 Taptic Engine Replacement, Heat the left edge: passo 6, immagine 1 di 1
    • Heat the left edge of the iPhone until the rear glass is slightly too hot to touch.
    Chiedi a FixBot
    Aggiungi Commento
  7. iPhone 14 Taptic Engine Replacement, Slice the left edge adhesive: passo 7, immagine 1 di 3 iPhone 14 Taptic Engine Replacement, Slice the left edge adhesive: passo 7, immagine 2 di 3 iPhone 14 Taptic Engine Replacement, Slice the left edge adhesive: passo 7, immagine 3 di 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Chiedi a FixBot
    Aggiungi Commento
  8. iPhone 14 Taptic Engine Replacement, Rear glass information: passo 8, immagine 1 di 1
    • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
    Chiedi a FixBot
    Aggiungi Commento
  9. iPhone 14 Taptic Engine Replacement, Heat the right edge: passo 9, immagine 1 di 1
    • Heat the right edge of the iPhone (the edge with the volume buttons) until the rear glass is slightly too hot to touch.
    Chiedi a FixBot
    Aggiungi Commento
  10. iPhone 14 Taptic Engine Replacement, Slice the right edge adhesive: passo 10, immagine 1 di 3 iPhone 14 Taptic Engine Replacement, Slice the right edge adhesive: passo 10, immagine 2 di 3 iPhone 14 Taptic Engine Replacement, Slice the right edge adhesive: passo 10, immagine 3 di 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
    Chiedi a FixBot
    Aggiungi Commento
  11. iPhone 14 Taptic Engine Replacement, Heat the top edge: passo 11, immagine 1 di 1
    • Heat the top edge of the iPhone until the rear glass is slightly too hot to touch.
    Chiedi a FixBot
    Aggiungi Commento
  12. iPhone 14 Taptic Engine Replacement, Slice the top edge adhesive: passo 12, immagine 1 di 3 iPhone 14 Taptic Engine Replacement, Slice the top edge adhesive: passo 12, immagine 2 di 3 iPhone 14 Taptic Engine Replacement, Slice the top edge adhesive: passo 12, immagine 3 di 3
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
    Chiedi a FixBot
    Aggiungi Commento
  13. iPhone 14 Taptic Engine Replacement: passo 13, immagine 1 di 3 iPhone 14 Taptic Engine Replacement: passo 13, immagine 2 di 3 iPhone 14 Taptic Engine Replacement: passo 13, immagine 3 di 3
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
    Chiedi a FixBot
    Aggiungi Commento
  14. iPhone 14 Taptic Engine Replacement, Open the iPhone: passo 14, immagine 1 di 3 iPhone 14 Taptic Engine Replacement, Open the iPhone: passo 14, immagine 2 di 3 iPhone 14 Taptic Engine Replacement, Open the iPhone: passo 14, immagine 3 di 3
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
    Chiedi a FixBot
    Aggiungi Commento
  15. iPhone 14 Taptic Engine Replacement, Unfasten the battery connector cover screws: passo 15, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Unfasten the battery connector cover screws: passo 15, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Chiedi a FixBot
    Aggiungi Commento
  16. iPhone 14 Taptic Engine Replacement, Remove the battery connector cover: passo 16, immagine 1 di 3 iPhone 14 Taptic Engine Replacement, Remove the battery connector cover: passo 16, immagine 2 di 3 iPhone 14 Taptic Engine Replacement, Remove the battery connector cover: passo 16, immagine 3 di 3
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  17. iPhone 14 Taptic Engine Replacement, Disconnect the battery: passo 17, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Disconnect the battery: passo 17, immagine 2 di 2
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Chiedi a FixBot
    Aggiungi Commento
  18. iPhone 14 Taptic Engine Replacement, Unfasten the charging coil connector cover screw: passo 18, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Unfasten the charging coil connector cover screw: passo 18, immagine 2 di 2
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  19. iPhone 14 Taptic Engine Replacement, Remove the charging coil connector bracket: passo 19, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Remove the charging coil connector bracket: passo 19, immagine 2 di 2
    • Use a pair of tweezers to remove the charging coil connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  20. iPhone 14 Taptic Engine Replacement, Disconnect the charging coil: passo 20, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Disconnect the charging coil: passo 20, immagine 2 di 2
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  21. iPhone 14 Taptic Engine Replacement, Remove the rear glass assembly: passo 21, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Remove the rear glass assembly: passo 21, immagine 2 di 2
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
    Chiedi a FixBot
    Aggiungi Commento
  22. iPhone 14 Taptic Engine Replacement, Remove the Taptic Engine screws: passo 22, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three 2.1 mm-long screws securing the Taptic Engine.
    Chiedi a FixBot
    Aggiungi Commento
  23. iPhone 14 Taptic Engine Replacement, Remove the Taptic Engine Connector Bracket: passo 23, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Remove the Taptic Engine Connector Bracket: passo 23, immagine 2 di 2
    • Use a pair of tweezers to remove the Taptic Engine connector bracket.
    Chiedi a FixBot
    Aggiungi Commento
  24. iPhone 14 Taptic Engine Replacement, Disconnect the Taptic Engine: passo 24, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Disconnect the Taptic Engine: passo 24, immagine 2 di 2
    • Use the pointed end of a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  25. iPhone 14 Taptic Engine Replacement, Remove the Taptic Engine: passo 25, immagine 1 di 2 iPhone 14 Taptic Engine Replacement, Remove the Taptic Engine: passo 25, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the Taptic Engine.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
123 Membri
31.535 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 106
Ultimi 30 giorni: 547
Tutti i Tempi: 12,835
