Salta al contenuto principale
iPad Wi-Fi LCD Replacement
Andrew Bookholt
Andrew Bookholt e 9 altri collaboratori
Ultimo aggiornamento il 10 mag 2021
40 minuti - 2 ore
Difficile
Introduzione
Vai al passo 1
Use this guide to replace your iPad's LCD.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. iPad Wi-Fi LCD Replacement, Display Assembly: passo 1, immagine 1 di 3 iPad Wi-Fi LCD Replacement, Display Assembly: passo 1, immagine 2 di 3 iPad Wi-Fi LCD Replacement, Display Assembly: passo 1, immagine 3 di 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    1) Are you recommending to cover the display with clear packing tape even if it is intact (not cracked)?
    2) If so,will the tape take the display’s oleophobic coating with it when removed?
    Mitch Stary - Replica
    Hola necesito comprar
    Alsone Michel - Replica
    Hola, ¿no estoy seguro si te refieres a las gafas de protección o a la pantalla? Te dejo los dos enlaces aquí:
    iPad LCD Panel
    Safety Glasses
    Sandra Hiller -
  2. iPad Wi-Fi LCD Replacement: passo 2, immagine 1 di 2 iPad Wi-Fi LCD Replacement: passo 2, immagine 2 di 2
    • In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
    • There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
    • If you do happen to break some clips, you can buy replacements here.
    A clearer explanation of the orientation is needed here. The bar code is at the top left of the iPad when you are looking at the screen.
    David Hincks - Replica
  3. iPad Wi-Fi LCD Replacement: passo 3, immagine 1 di 2 iPad Wi-Fi LCD Replacement: passo 3, immagine 2 di 2
    • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    Tip* "ONLY WITH METAL SPUDGER* heat it with a lighter till its warm to touch, then slide it like a butter knife. it reduces chances of chipping glass.
    luckie - Replica
    I've found that by using a thicker iPad tool dents the back less(not at all if your careful) and start prying just under the volume button and working my way down works better as the metal clips are on all sider except the right side.
    richard - Replica
    It would be really helpful to point out where all the clips and tabs are, and to show a picture of them (unbroken), so you know what you're trying to release.
    Styg - Replica
  4. iPad Wi-Fi LCD Replacement: passo 4, immagine 1 di 2 iPad Wi-Fi LCD Replacement: passo 4, immagine 2 di 2
    • With one spudger, work your way along the right edge of the iPad.
    • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
    • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
    • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
    Its seems easier to undo the clips on the left and bottom by levering them with an iPad tool and pusing the clips in from the edge with another tool when i can visually see them. One the right side, bottom and most of the left side is done there isnt much need to do the top as it will slide off if moved about a centimeter
    richard - Replica
  5. iPad Wi-Fi LCD Replacement: passo 5, immagine 1 di 1
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
    By it's BOTTOM edge.
    jonathan - Replica
  6. iPad Wi-Fi LCD Replacement: passo 6, immagine 1 di 1
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
    It would be easier to detach the Display Data Cable at its connector on the far right in the picture, since there doesnt seem to be much play to undo the suggested one.
  7. iPad Wi-Fi LCD Replacement: passo 7, immagine 1 di 3 iPad Wi-Fi LCD Replacement: passo 7, immagine 2 di 3 iPad Wi-Fi LCD Replacement: passo 7, immagine 3 di 3
    • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
    Adding this comment in its proper place:
    After flipping up the metal retainer, pull it sideways.
    Do not pull it up vertically.
    Joe in PA
  8. iPad Wi-Fi LCD Replacement: passo 8, immagine 1 di 1
    • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  9. iPad Wi-Fi LCD Replacement: passo 9, immagine 1 di 2 iPad Wi-Fi LCD Replacement: passo 9, immagine 2 di 2
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
    IMHO, unhooking data display cable from the other end is preferable to the above location, since the cable itself is sealed or taped onto the assembly.
    Roger Buttermore - Replica
  10. iPad Wi-Fi LCD Replacement: passo 10, immagine 1 di 1
    • Remove the display assembly from the rear panel assembly.
  11. iPad Wi-Fi LCD Replacement, Ambient Light Sensor: passo 11, immagine 1 di 3 iPad Wi-Fi LCD Replacement, Ambient Light Sensor: passo 11, immagine 2 di 3 iPad Wi-Fi LCD Replacement, Ambient Light Sensor: passo 11, immagine 3 di 3
    • If you are reusing the LCD, it is not necessary to peel the ambient light sensor off the back face of the LCD.
    • Use the edge of a plastic opening tool to carefully pry the ambient light sensor board off the adhesive securing it to the display frame.
    • Once you've gained enough clearance, peel the ambient light sensor off the LCD.
    • Be careful not to crease the ambient light sensor below its top section, as the portion with adhesive applied may break off.
    • If necessary, attach the plastic view window to your new ambient light sensor before installation.
    You can leave the sensor stuck to the LCD if you're reusing the LCD. It just stays attached to the LCD no problem.
    jonathan - Replica
    Step 7 after flipping up the metal retainer, pull it sideways.
    Joe in PA - Replica
    I added your comment in the proper place at Step 7
    David Hincks -
  12. iPad Wi-Fi LCD Replacement, LCD: passo 12, immagine 1 di 1
    • While holding the digitizer cable down, carefully peel back the piece of tape connecting the digitizer cable to the display frame.
  13. iPad Wi-Fi LCD Replacement: passo 13, immagine 1 di 2 iPad Wi-Fi LCD Replacement: passo 13, immagine 2 di 2
    • Remove the three T5 Torx screws securing the clips and LCD brackets covered in EMI tape near the home button switch.
    • Carefully peel the display clip and its attached tape off the black plastic display frame.
    • If you are replacing the LCD, be sure to transfer these pieces of EMI tape and their attached clips to the new LCD.
  14. iPad Wi-Fi LCD Replacement: passo 14, immagine 1 di 1
    • Remove the remaining T5 Torx screws securing the LCD to the black plastic display frame.
    I see that the author broke 4 tabs on the top and 2 tabs on the bottom -- the exact same ones that I broke. I must be following his instructions perfectly!
    Styg - Replica
  15. iPad Wi-Fi LCD Replacement: passo 15, immagine 1 di 2 iPad Wi-Fi LCD Replacement: passo 15, immagine 2 di 2
    • Insert the edge of a plastic opening tool under one of the ears attached to the steel LCD frame.
    • Twist the plastic opening tool to gently pry the LCD up off the adhesive securing it to the front glass panel.
    • Be sure not to excessively bend the LCD, as it is made of glass.
  16. iPad Wi-Fi LCD Replacement: passo 16, immagine 1 di 1
    • Repeat the process detailed on the previous step to pry up the display around the three sides opposite the digitizer cable side of the display.
  17. iPad Wi-Fi LCD Replacement: passo 17, immagine 1 di 2 iPad Wi-Fi LCD Replacement: passo 17, immagine 2 di 2
    • Lift the LCD from its free end, and remove it from the display frame.
    • Carefully peel the adhesive securing the long side of the LCD to the display frame, then remove the LCD.
    remove the home button spring assembly from the old digitizer and transfer it to the new one!!!!!!!!!
    wh1513 - Replica
  18. iPad Wi-Fi LCD Replacement: passo 18, immagine 1 di 1
    • If it is still stuck to the front panel, remove the strip of EMI tape near the ambient light sensor socket.
    • If necessary, transfer this to your new LCD.
    • If it is attached to the LCD and you are reusing the LCD, skip this step. If you are replacing the LCD as well, transfer the strip of EMI tape to your new LCD.
    Jeez!! Please put to keep the emi tape if you are resusing your lcd BEFORE the step that says to remove it...I don't know how import this stuff is, but I'm guessing pretty important cause I just removed it.
    Noah - Replica
  19. iPad Wi-Fi LCD Replacement: passo 19, immagine 1 di 1
    • If they are still in good shape, transfer the clips and EMI tape near the bottom of the LCD to your new LCD.
Conclusione
Altre 79 persone hanno completato questa guida.
4Commenti sulla guida
So what if ive snapped off one of the retaining flaps? Ive seen in the past when ive snapped them off before i could just plug it in, slap on some kapton tape and it was fine. This time i cant get the bottom of the digitizer to work on new glass. I put on the old glass and the bottom works just fine. the bottom flap is the one that broke, but why would the old glass work just fine, but the new glass does nothing on the bottom half?
Blib - Replica
Just replaced my lcd using this guide. Not easy, but doable. Took about an hour and a half. broke about half of the clips that hold the assembly in, but moved the remaining ones around so that it is secure. I recommend buying replacement clips if you aren't comfortable with that. Also, this guide says to use a Torx T5 screwdriver. Other sites say T4. It is most definitely T5. I bought the wrong one first and had to get a new one. Home Depot has an 8 in 1 Torx tool for 6 bucks that is great. Thank you iFixit for saving me hundreds that I would have spent on a new iPad!
dcook88 - Replica
Don't worry about buying more replacment clips -- if you still have them on the left edge, not having the clips on the top and bottom isn't noticeable.
Styg -
When reassembling at the last step (inserting the screen assembly into the back cover), do NOT simply do the reverse of what you did to take it out. Instead, insert the right edge first (with the plastic tabs). The metal tabs on the left edge (and top and bottom edges if you have any left) are flexible, so it is very easy to snap the left edge of the screen into the back cover AFTER the right edge is in place. If you put the left edge in first, you'll have a much tougher time trying to get the plastic tabs on the right edge into back cover.
Styg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 59
Tutti i Tempi: 212,366
