iHome IH11 Dock Connector Replacement
Introduzione
Vai al passo 1Replace the dock connector on your iHome iP11, so you can play music and charge your battery once again. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
Cosa ti serve
Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
Likewise, this guide isn't much good if it uses parts that are unavailable.
