Salta al contenuto principale
iHome IH11 Dock Connector Replacement
Nick Knowles
Nick Knowles e 7 altri collaboratori
Ultimo aggiornamento il January 28, 2014
5 - 10 minuti
Moderato
Foto Azione
Introduzione Migliore
Introduzione
Vai al passo 1
Replace the dock connector on your iHome iP11, so you can play music and charge your battery once again. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
Cosa ti serve
Ricambi
Strumenti
  1. iHome IH11 Dock Connector Replacement, Dock Connector: passo 1, immagine 1 di 1
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: passo 2, immagine 1 di 2 iHome IH11 Dock Connector Replacement: passo 2, immagine 2 di 2
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: passo 3, immagine 1 di 1
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
Conclusione
Altre 3 persone hanno completato questa guida.
Nick Knowles
Membro da: 04/19/13
21 Reputazione
2 Guide realizzate
Cal Poly, Team 14-9, Maness Spring 2013 Membro di Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Membri
5 Guide realizzate
2 Commenti
Where can I buy a replacement dock connector?
A Ross - Replica
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,421
