Salta al contenuto principale
iBook G4 12" 1.33 GHz Keyboard Replacement
Walter Galan
Walter Galan e 3 altri collaboratori
Ultimo aggiornamento il July 31, 2013
Nessuna stima
Facile
Introduzione
Vai al passo 1
Replacing this keyboard is easy and takes only a few minutes.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: passo 1, immagine 1 di 2 iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: passo 2, immagine 1 di 2 iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: passo 2, immagine 2 di 2
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 12" 1.33 GHz Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the four silver Phillips screws that secure the RAM shield.
  4. iBook G4 12" 1.33 GHz Keyboard Replacement: passo 4, immagine 1 di 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
    Hi please help me
    mominshahbaz922 - Replica
Conclusione
Altre 10 persone hanno completato questa guida.
Documenti Allegati
1Commento della guida
The screw is stripped. What should I do?
TheYootz Media Group - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 26
Tutti i Tempi: 10,399
