Salta al contenuto principale
Vornado Duo Fuse Replacement
Tyler Pettenger
Tyler Pettenger e 3 altri collaboratori
Ultimo aggiornamento il March 7, 2024
2 minuti
Facile
Introduzione
Vai al passo 1
In this replacement guide, step-by-step instructions show how to approach replacing the fuse in the power cord plug of the Vornado Duo.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Vornado Duo Fuse Replacement, Fuse: passo 1, immagine 1 di 1
    • Grasp plug and remove from the receptacle or other outlet device.
    • Do not unplug by pulling on cord.
  2. Vornado Duo Fuse Replacement: passo 2, immagine 1 di 1
    • Open fuse cover by sliding access cover on top of attachment plug.
  3. Vornado Duo Fuse Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove fuse carefully by gently prying out the ends of the fuse from the receptacle again using the driver with the 2mm flathead.
    • Risk of fire. Replace fuse only with 2.5 Amp, 125 Volt fuse.
  4. Vornado Duo Fuse Replacement: passo 4, immagine 1 di 1
    • Install replacement fuse by first placing the end of the fuse into the fuse receptacle which is opposite of the blades of the plug, then carefully push in the other end. (Only push against the metal end of the fuse, not the glass center portion)
  5. Vornado Duo Fuse Replacement: passo 5, immagine 1 di 1
    • Close the fuse access cover by sliding the cover back into the plug until it is completely closed, latches and is flush with the face of the plug. (Risk of fire. Do not replace attachment plug. Contains a safety device that should not be removed.)
Linea Traguardo
Altre 6 persone hanno completato questa guida.
USF Tampa, Team S1-G1, Nance Fall 2017 Membro di USF Tampa, Team S1-G1, Nance Fall 2017
USFT-NANCE-F17S1G1
3 Membri
4 Guide realizzate
6Commenti sulla guida
It’s still not working for me - I’ve cleaned the whole fan, put it back together and changed the fuse. Any tips? Thank you.
Whitney Sturner - Replica
Did you ever get an answer? I'm having the same problem
bysgamer617 - Replica
Probably a damaged circuit board capacitor, search out a micro-electronic repair shop. Or, authorized dealer. Often you can find a repair that understands multiple board systems and can easily test and repair your fan. An example, Apple technologies.
GW Roberts (GW) - Replica
Please remember, if you purchase the fan from any source other than an authorized dealership, who has invested money and training, the manufacturer has NO responsibility to that unauthorized purchase.
Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.
Djlaine17 - Replica
People are scaring you not to replace with non-fuse plugs. Many appliances like toaster and blender have no fuses. I replaced with a plug without a fuse and my fan works perfectly. So don't listen to scammers
Girish Modi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 67
Tutti i Tempi: 15,875
