Salta al contenuto principale
VTech VM3254 Monitor Circuit Board and Screen Replacement
Christina Block
Christina Block e 3 altri collaboratori
Ultimo aggiornamento il 18 mag 2023
10 minuti
Moderato
Introduzione
Vai al passo 1
If there is no image coming from the parents monitor this could mean that both the screen and circuit board need to be replaced. In order to replace the screen, you need a Phillips #00 Screwdriver. In order to remove the circuit board, you will need a cord solder. This does not include any difficult steps, as long as you are gently removing the circuit board and screen.
Cosa ti serve
Strumenti
Mostra di più…
  1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: passo 1, immagine 1 di 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 2, immagine 1 di 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 2, immagine 2 di 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 2, immagine 3 di 3
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 3, immagine 1 di 2 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 3, immagine 2 di 2
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 4, immagine 1 di 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 4, immagine 2 di 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 4, immagine 3 di 3
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
    Wo finde ich denn genau solch eine Batterie ?
    Besten Gruß
    René
    kroenung1990@googlemail.com
    René Krönung - Replica
  5. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: passo 5, immagine 1 di 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: passo 5, immagine 2 di 2
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
  6. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 6, immagine 1 di 1
    • Desolder the wire connecting the speaker to the board.
  7. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: passo 7, immagine 1 di 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: passo 7, immagine 2 di 2
    • Remove the three 8 mm Phillips #00 screws.
    • Gently remove the screen and circuit board from the case.
  8. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 8, immagine 1 di 2 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 8, immagine 2 di 2
    • Remove the button assembly from the front of the screen unit.
    • Flip the screen unit back over and desolder the wire holding it to the case.
Conclusione
1Commento della guida
Any source for replacement screens?
Rob Olivieri - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 50
Tutti i Tempi: 1,179
