VTech Little Apps Tablet Screen Replacement
Introduzione
Vai al passo 1The screen of the device is attached to the motherboard by a ribbon cable, which is a fragile piece of circuitry. This guide will help you in removing the screen from the motherboard without damaging these elements.
Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
Unscrew the two 7.3 mm screws using a PH0 driver head.
Gently lift the beige circuit board and set aside.
Carefully lift both the screen and motherboard, to access to the ribbon cable underneath.
Use a heat gun (or hair dryer) to apply low heat to the ribbon cable attachment on the motherboard.
Carefully use a nylon spudger to separate the ribbon cable from the motherboard and remove the screen.
Preparati per le riparazioni future
Acquista tutti
