VHS Shell Replacement
Introduzione
Vai al passo 1In this guide, you will learn step-by-step instructions on how to replace the broken shell of a VHS tape when it is too broken to work correctly in a VHS player. In doing this repair, you will be able to salvage the tape so that it can be digitized or continue to be watched. No special skills are needed for this repair, with a screwdriver being the only tool used. It is recommended that you cut or rip off any labels on the sides of the tape before beginning, so that it will be easier to take the top half of the shell off.
Cosa ti serve
Strumenti
Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
The tape goes up to the left of the plastic piece and to the right of the metal piece, then over to the left
Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
The tape goes over the large metal piece then down between the triangle and the small metal piece.
2Commenti sulla guida
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. -
