Toshiba Satellite U840W 12V Charging Port Replacement
Introduzione
Vai al passo 1Removing this piece makes working inside of the computer easier. To replace this part (if it is broken) follow this guide.
Cosa ti serve
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
Altre 2 persone hanno completato questa guida.
