Salta al contenuto principale
Toshiba Satellite U840W Processor Fan Replacement.
Cosa ti serve
  1. Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: passo 1, immagine 1 di 2 Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: passo 1, immagine 2 di 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W Processor Fan Replacement.: passo 2, immagine 1 di 3 Toshiba Satellite U840W Processor Fan Replacement.: passo 2, immagine 2 di 3 Toshiba Satellite U840W Processor Fan Replacement.: passo 2, immagine 3 di 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W Processor Fan Replacement.: passo 3, immagine 1 di 3 Toshiba Satellite U840W Processor Fan Replacement.: passo 3, immagine 2 di 3 Toshiba Satellite U840W Processor Fan Replacement.: passo 3, immagine 3 di 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W Processor Fan Replacement.: passo 4, immagine 1 di 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: passo 6, immagine 1 di 2 Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: passo 6, immagine 2 di 2
    • Remove the three 3mm screws using a Phillips #00 screwdriver.
  6. Toshiba Satellite U840W Processor Fan Replacement.: passo 7, immagine 1 di 2 Toshiba Satellite U840W Processor Fan Replacement.: passo 7, immagine 2 di 2
    • A plastic prying tool can be used to help you remove the fan.
    • Plastic wire guides hold the wire in place. Manipulate the wire out from these guides.
  7. Toshiba Satellite U840W Processor Fan Replacement.: passo 8, immagine 1 di 2 Toshiba Satellite U840W Processor Fan Replacement.: passo 8, immagine 2 di 2
    • Remove the connector from the motherboard.
Conclusione
Tony Aprile
Membro da: 02/04/19
118 Reputazione
1 Guida realizzata
Gateway, Team S1-G1, Saknee Spring 2019 Membro di Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 351
