Salta al contenuto principale
TP-Link MR3040 Wireless Router Disassembly
steve
steve e un altro collaboratore
Ultimo aggiornamento il July 23, 2018
5 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Kudos to hackeritalics at https://www.youtube.com/watch?v=2ya8yov8... for getting me the gist. What this does is show you the hidden tabs to release in order to open up the case without breaking it.
Cosa ti serve
Strumenti
Mostra di più…
  1. TP-Link MR3040 Wireless Router Disassembly, TP-Link MR3040 Wireless Router Disassembly: passo 1, immagine 1 di 1
    • First, open the case by prying off the bottom the same way you access the battery. Use a thumbnail on this side and the other side
  2. TP-Link MR3040 Wireless Router Disassembly: passo 2, immagine 1 di 2 TP-Link MR3040 Wireless Router Disassembly: passo 2, immagine 2 di 2
    • This is also how you install or remove the battery
  3. TP-Link MR3040 Wireless Router Disassembly: passo 3, immagine 1 di 1
    • First, use a small Philips head screwdriver - a 00 worked for me - and remove the two screws indicated by the ORANGE stars.
    • The four yellow stars indicate where you will be prying the TABS away
  4. TP-Link MR3040 Wireless Router Disassembly: passo 4, immagine 1 di 1
    • This is what it will look like taken apart. The white plate at the top of the picture is the plate you will be removing. The gray plate is where the circuit board sits. In this picture the circuit board is already removed.
    • NOTE that there are also tabs at the ends of the router, I noted one with a red X -- you don't need to worry about those, they slip off once you get the other tabs loose.
  5. TP-Link MR3040 Wireless Router Disassembly: passo 5, immagine 1 di 2 TP-Link MR3040 Wireless Router Disassembly: passo 5, immagine 2 di 2
    • The latch is on the white case. The tabs are on the gray case. You will be pushing the white latch AWAY from the gray tabs.
    • Put your flat blade to the OUTBOARD side of the white latch in the hole. Push INBOARD to pry it OFF of the tabs, pushing down through the hole at the same time in order to push the white case off. You'll want to hold the router by the gray if you can.
    • As you push the latch you'll obviously need to try to pry the two pieces apart like with your fingernail.
Conclusione
To reassemble your device, snap it back together. Bear in mind that if you remove the circuit board you'll need to align the power and other switch with their carriers in the gray case.
steve
Membro da: 08/01/16
1.433 Reputazione
3 Guide realizzate
1Commento della guida
it's so weird seeing a video I made being referenced by somebody. Lol it's nice to see that it helps someone!
hackeritalics - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,963
