Salta al contenuto principale
Switch Pro Controller Case Replacement
Jean Galindez
Jean Galindez e 10 altri collaboratori
Ultimo aggiornamento il 28 set 2024
20 minuti
Moderato
Introduzione
Vai al passo 1
This guide is used for the replacement of the case on your Nintendo Switch Pro Controller. Take precaution when completing this guide because it involves the removal of a lithium-ion battery. If the battery is swollen, check out this resource on how to dispose of a swollen battery. To complete this guide correctly you must complete steps eight and nine with caution so as to not damage the white ribbon cable.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Switch Pro Controller Case Replacement, Remove the screws: passo 1, immagine 1 di 1
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
  2. Switch Pro Controller Case Replacement, Remove the handle covers: passo 2, immagine 1 di 3 Switch Pro Controller Case Replacement, Remove the handle covers: passo 2, immagine 2 di 3 Switch Pro Controller Case Replacement, Remove the handle covers: passo 2, immagine 3 di 3
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Switch Pro Controller Case Replacement, Remove the screws: passo 3, immagine 1 di 1
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Switch Pro Controller Case Replacement, Unclip the plastic cover: passo 4, immagine 1 di 3 Switch Pro Controller Case Replacement, Unclip the plastic cover: passo 4, immagine 2 di 3 Switch Pro Controller Case Replacement, Unclip the plastic cover: passo 4, immagine 3 di 3
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Switch Pro Controller Case Replacement, Remove the clear plastic cover: passo 5, immagine 1 di 1
    • Remove the clear plastic cover.
  6. Switch Pro Controller Case Replacement, Remove the battery: passo 6, immagine 1 di 3 Switch Pro Controller Case Replacement, Remove the battery: passo 6, immagine 2 di 3 Switch Pro Controller Case Replacement, Remove the battery: passo 6, immagine 3 di 3
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
  7. Switch Pro Controller Case Replacement, Remove the screws: passo 7, immagine 1 di 3 Switch Pro Controller Case Replacement, Remove the screws: passo 7, immagine 2 di 3 Switch Pro Controller Case Replacement, Remove the screws: passo 7, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
  8. Switch Pro Controller Case Replacement: passo 8, immagine 1 di 3 Switch Pro Controller Case Replacement: passo 8, immagine 2 di 3 Switch Pro Controller Case Replacement: passo 8, immagine 3 di 3
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
  9. Switch Pro Controller Case Replacement, Open the flap: passo 9, immagine 1 di 2 Switch Pro Controller Case Replacement, Open the flap: passo 9, immagine 2 di 2
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
  10. Switch Pro Controller Case Replacement, Disconnect the interconnect cable: passo 10, immagine 1 di 2 Switch Pro Controller Case Replacement, Disconnect the interconnect cable: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
  11. Switch Pro Controller Case Replacement, Remove the front case: passo 11, immagine 1 di 1
    • Remove the front case.
Conclusione
Altre 21 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
3Commenti sulla guida
I wondered why Xbox X controllers grips were difficult to remove and also make a squeak sound when the plastic part is not closing properly but a double-sided tape should do it...
Nicholin V - Replica
Disassembly was fine, but reassembly was a bit trickier. Removing the front casing from the chassis as in step 8 required a bit of force, since it seemed like the two were clipped together. Putting the two together, I can't seem to find where exactly that clipping connection was. I'd ignore it and move on to the screws, but it doesn't fit flush and I'm left with this narrow gap at the top that seems to be causing trouble. Any idea where I should be looking/applying pressure?
winter - Replica
At step eight, the easiest way to separate the two halves is to use your triangle pry tool, on the sides, underneath where the handle covers are, on both sides. I thought that I had missed a screw or something but that wasn't true. Just slowly pull them apart, I used this guide to clean my pro controller, thanks!
AvariceHW - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 110
Ultimi 30 Giorni: 504
Tutti i Tempi: 24,595
