Salta al contenuto principale
SuperSonic Matrix Mid SC-999 LCD Replacement
Harris Dagha
Harris Dagha e 3 altri collaboratori
Ultimo aggiornamento il May 15, 2019
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
In this guide you will remove the back cover of the device and partially remove the motherboard. Disconnect the screen from the motherboard using a soldering iron and replace it with a new screen.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Cosa ti serve
Strumenti
Mostra di più…
  1. SuperSonic Matrix Mid SC-999 LCD Replacement, Back Cover: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 LCD Replacement: passo 2, immagine 1 di 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 LCD Replacement: passo 3, immagine 1 di 2 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 3, immagine 2 di 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: passo 4, immagine 1 di 3 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: passo 4, immagine 2 di 3 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: passo 4, immagine 3 di 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 LCD Replacement: passo 5, immagine 1 di 3 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 5, immagine 2 di 3 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 5, immagine 3 di 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
    After i replaces the battery it still doesn't work
    daledelorise - Replica
  6. SuperSonic Matrix Mid SC-999 LCD Replacement, Speaker: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
    Should you have two photos? Is it clear where you removed the speaker from?
    Should you note here that the speaker has wires that will also need to be removed?
    Do you ever mention the tape?
    Lisa Shaver - Replica
  7. SuperSonic Matrix Mid SC-999 LCD Replacement: passo 7, immagine 1 di 2 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 7, immagine 2 di 2
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    Again, you are telling what to do, not how to do it.
  8. SuperSonic Matrix Mid SC-999 LCD Replacement, Microphone: passo 8, immagine 1 di 1
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  9. SuperSonic Matrix Mid SC-999 LCD Replacement: passo 9, immagine 1 di 2 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 9, immagine 2 di 2
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
  10. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: passo 10, immagine 1 di 2 SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: passo 10, immagine 2 di 2
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
  11. SuperSonic Matrix Mid SC-999 LCD Replacement: passo 11, immagine 1 di 2 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 11, immagine 2 di 2
    • Desolder the FM antenna from the motherboard.
  12. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: passo 12, immagine 1 di 2 SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: passo 12, immagine 2 di 2
    • Remove the large ribbon cable from the socket that attaches it to the motherboard.
    • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
  13. SuperSonic Matrix Mid SC-999 LCD Replacement: passo 13, immagine 1 di 2 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 13, immagine 2 di 2
    • Remove the small ribbon cable from the socket that attaches it to the motherboard.
    • Flip the dark grey latch to release the ribbon cable from the motherboard.
  14. SuperSonic Matrix Mid SC-999 LCD Replacement: passo 14, immagine 1 di 3 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 14, immagine 2 di 3 SuperSonic Matrix Mid SC-999 LCD Replacement: passo 14, immagine 3 di 3
    • Remove the four Phillips #00 screws attaching the motherboard to the device.
  15. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: passo 15, immagine 1 di 3 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: passo 15, immagine 2 di 3 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: passo 15, immagine 3 di 3
    • Ensure that the motherboard and all other items are off before continuing.
    • Separate the screen and back housing by gently pulling on it.
Conclusione
Altre 4 persone hanno completato questa guida.
Dr Shaverz boyz Membro di Dr Shaverz boyz
Community
3 Membri
14 Guide realizzate
1Commento della guida
what is the part number & where can I get a replacement screen for the SC-8809
impaired27 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,104
