Spin Master Boxer Wheel Gears Replacement
Introduzione
Vai al passo 1If Robot fails to move, the gears inside of wheels may need to be replaced. Follow this guide for instructions on how to access and replace gears. This can be applied to both sets of wheels. You will need a Phillips #00 Screwdriver and tweezers.
Cosa ti serve
Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
Gently separate the left set of wheels from the inner portion of the circuit board, by gripping the wheels and pulling them away from main body of robot.
Repeat the process for the right set of wheels.
I just want to know the type of the black transistor in the black wheel.
Thanks.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using tweezers, grip defective gear, and pull up and out of gear system to replace.
my problem is the motor it wont respond, where can i buy same motor what size.?
Preparati per le riparazioni future
Acquista tutti3Commenti sulla guida
This is super useful guide and picture are clear for the steps. Will be excellent to know where to buy these gears replacements?
Hello. Thé motor seems to be broken. Do you Knowles ils spec to buy à New one.
Sorry, im french...
Tanks.
Do you know its spec to buy a new one?
Realy sorry...
think you i can fix
Darren Davis - Replica
