Salta al contenuto principale
Spin Master Boxer Wheel Gears Replacement
Lauren Roide
Lauren Roide e 4 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
8 minuti
Moderato
Introduzione
Vai al passo 1
If Robot fails to move, the gears inside of wheels may need to be replaced. Follow this guide for instructions on how to access and replace gears. This can be applied to both sets of wheels. You will need a Phillips #00 Screwdriver and tweezers.
Cosa ti serve
Strumenti
  1. Spin Master Boxer Wheel Gears Replacement, Robot Screen: passo 1, immagine 1 di 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
    think you i can fix
    Darren Davis - Replica
  2. Spin Master Boxer Wheel Gears Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
    how can i easier when there broken?
    Daniel Ellingson - Replica
  3. Spin Master Boxer Wheel Gears Replacement: passo 3, immagine 1 di 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Wheel Gears Replacement: passo 4, immagine 1 di 2 Spin Master Boxer Wheel Gears Replacement: passo 4, immagine 2 di 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Wheel Gears Replacement: passo 5, immagine 1 di 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Wheel Gears Replacement, Robot Wheel Gears: passo 6, immagine 1 di 1
    • Place robot on back so that the sensors are facing up.
  7. Spin Master Boxer Wheel Gears Replacement: passo 7, immagine 1 di 2 Spin Master Boxer Wheel Gears Replacement: passo 7, immagine 2 di 2
    • Gently separate the left set of wheels from the inner portion of the circuit board, by gripping the wheels and pulling them away from main body of robot.
    • There are wires attached to each set of wheels, so be careful not to rip them apart.
    • Repeat the process for the right set of wheels.
    I just want to know the type of the black transistor in the black wheel.
    Thanks.
    Nabeel AlMusawy - Replica
  8. Spin Master Boxer Wheel Gears Replacement: passo 8, immagine 1 di 2 Spin Master Boxer Wheel Gears Replacement: passo 8, immagine 2 di 2
    • Use the Phillips #00 Screwdriver to remove the 3mm screw that connect the black wheels to the gears.
    • You will have to go through the black wheel to unscrew some of the screws.
  9. Spin Master Boxer Wheel Gears Replacement: passo 9, immagine 1 di 3 Spin Master Boxer Wheel Gears Replacement: passo 9, immagine 2 di 3 Spin Master Boxer Wheel Gears Replacement: passo 9, immagine 3 di 3
    • Grip wheel, and gently pull up, to separate white gear casing into its front and back panel.
  10. Spin Master Boxer Wheel Gears Replacement: passo 10, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, grip defective gear, and pull up and out of gear system to replace.
    my problem is the motor it wont respond, where can i buy same motor what size.?
    dlonewolf angel - Replica
    en donde puedo conseguir los engranes soy de cdmx
    meche - Replica
Conclusione
Preparati per le riparazioni future
Acquista tutti
Lauren Roide
Membro da: 04/16/19
739 Reputazione
5 Guide realizzate
Cal Poly, Team S1-G1, Maness Spring 2019 Membro di Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Membri
10 Guide realizzate
3Commenti sulla guida
This is super useful guide and picture are clear for the steps. Will be excellent to know where to buy these gears replacements?
Javier Perez - Replica
Hello. Thé motor seems to be broken. Do you Knowles ils spec to buy à New one.
Sorry, im french...
Tanks.
Jerome Carbonneaux - Replica
Do you know its spec to buy a new one?
Realy sorry...
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,930
