Sostituzione batteria Harman Kardon Onyx Studio 2
Introduzione
Vai al passo 1Dopo aver completato la guida prerequisita per rimuovere il pannello frontale della cassa, potrai accedere alla batteria per sostituirla una volta esausta.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Usando uno strumento di appertura in plastica, rimuovi la griglia frontale facendo leva sulla fossetta posizionata davanti il dispositivo.
Rimuovi le cinque viti Torx T10 da 14.4 mm.
There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
Rimuovi i 4 cavi che collegano il pannello frontale a quello dietro.
Scollega delicatamente la linguetta del connettore.
Ripeti la procedura per gli altri tre connettori.
Svita le tre viti Torx T10 da 10,4 mm dalla copertura della batteria.
Rimuovi la copertura della batteria.
Tira fuori la batteria per sostituirla.
What battery is the replacement? Are there one or two batteries inside? Could have been a good “how to instruction” but left out some important facts. Duh?
You should include that the battery compartment is in the BACK.
Also, there are two compartments in the back. I tried to open the wrong one.
My torx socket didn't fit into the central hole of that compartment. Arrrgh! So I used a drill to make the hole bigger, only to find upon opening that it was the wrong compartment.
The correct one was easier to open. (!) I found I needed to wrap part of the new battery in electrical tape to avoid it rattling around.
Putting it all back together had two challenges. There's a very thin rubber gasket that has to be delicately pressed back into its channel. Also, the larger rubber surround has to be placed appropriately on the various buttons (power, volume, Bluetooth).
I'd rate this as “medium" difficulty.
BTW, the correct replacement for the single battery is easily found online by searching “replacement battery Harman Kardon Onyx Studio”. (Student One and Two use the same battery.)
Super
merci Infiniment pour ce tutoriel
This guide is not correct for all models. For Onyx studio 2, you have to open BOTH front and back panels and remove the metal stand. The screws are located under the back panel (regular Phillips screws and not Torx). Battery is a 11.1V 2500mAh (28Wh) model no. PR-633496
Très bonnes explications merci. Je viens de changer pour la première fois la batterie.
Quelques notes :
1) J'ai récupéré les mousses anti vibrations de l'ancienne batterie pour les recoller sur la nouvelle.
2) J'ai aussi récupéré (en coupant) le caoutchouc triangulaire qui lie les 3 fils électriques. Il permet de fixer les fils ensemble et surtout fixer la batterie dans le compartiment (les rainures sont faites pour ça).
Bonjour, je n’ai jamais eu de chargeur batterie pour ma Ontx studio 2, quelqu’un peut-il me dire où je peux en acheter un svp? En vous remerciant par avance pour votre retour cordialement
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
Altre 47 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Daniele Carminati ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
21 Commenti
Thanks for the step by step instructions. I have tried replacing the batteries but the speaker still won't turned on. I believe the battery cable/module is broken, do you know how to fix it? Thanks.
Can you put a step by step instruction how to replace a battery on a Harman/ Kardon esquire 2?
Can you tell me what kind of the hk onyx speaker battery's, if you can show me step instructions to replace! Thankyou!
Hello,
Where I can buy those 14.4 mm T10 Torx screws online?
Hello
What is the battery for the Harman Kardon Esquire 2 speaker?
Regards
Here is where you can find a good battery. https://www.ebay.com/itm/192530902153
What if the wires connected to the battery were splice for another battery hook up .and a wire on the battery broke and my charging ports are no good what can i do
Is it possible to use just the power supply
The battery of onix 2 could work to Harman kardon onix 1?
Thanks for the easy replacement instructions. Our school bought 4 of the 1st generation HK Onyx speakers and all 4 batteries bit the dust this year. It was a breeze to find better replacements than the original on Amazon and Ebay and these instructions gave me the confidence to disassemble, replace, and reassemble the speakers. Everybody thinks I’m a genius. Thanks again.
Can i replace Hk onyx 3 battery with hk onyx 4 battery?
I need a panel of Harman kardon studio 4
Where can I find a new front panel for my speaker
consomme69 - Replica
If I take this off can I put it back on
Burger King - Replica
