Salta al contenuto principale
Sony XPERIA Tablet Z Screen Replacement
Gustavo Correa
Gustavo Correa e 4 altri collaboratori
Ultimo aggiornamento il January 15, 2018
1 ora
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the display on your Sony XPERIA Tablet Z.
This guide will take you through the process of removing the display and connection points to the motherboard.
This will require heating the screen to remove the adhesive be very careful as too much heat can damage the tablet its self.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, immagine 1 di 3 Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, immagine 2 di 3 Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: passo 2, immagine 1 di 3 Sony XPERIA Tablet Z Screen Replacement: passo 2, immagine 2 di 3 Sony XPERIA Tablet Z Screen Replacement: passo 2, immagine 3 di 3
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: passo 3, immagine 1 di 1
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: passo 4, immagine 1 di 1
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: passo 5, immagine 1 di 1
    • Clean adhesive from perimeter of frame to prepare for new screen.
Conclusione
Altre 8 persone hanno completato questa guida.
IUPUI, Team S5-G1, Harley Summer 2017 Membro di IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Membri
3 Guide realizzate
5Commenti sulla guida
اريدشراءاريدشراءشاشه جديده
kore ares - Replica
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Replica
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Replica
Wooo its self explanatory.Good work
Duncan Mwaniki - Replica
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 7,809
