Salta al contenuto principale
Shark ION Robot R75 Side Sensor Replacement
Andrew Lowy
Andrew Lowy e 3 altri collaboratori
Ultimo aggiornamento il 16 mar 2020
40 minuti
Moderato
Introduzione
Vai al passo 1
Your robot navigates through a combination of random movements and sensors to guide it around a room. This guide will show you how to access two of these senors in the event that they fail and need to be replaced. Faulty senors will result in sporadic robot movement, more frequent collisions, and the robot eventually flashing error codes.
Remember to periodically clean all sensors with a dry microfiber cloth to keep your R75 performing properly.
Cosa ti serve
Strumenti
Mostra di più…
  1. Shark ION Robot R75 Side Sensor Replacement, Battery: passo 1, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement, Battery: passo 1, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the robot is shut off by pressing the power button on top.
    • Flip the R75 over so that the underside is facing up.
    • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
    • Remove the battery cover.
    Here, you have misused the reminder bullet. The note bullet would be better in this case; I would also say how to turn it off, rather than just to do it. Avoid locate steps, and instead, move straight to the information about what to do. Use markup on the images to indicate where the component is. Be careful about using “remove” without other information about how to remove it, especially if there are multiple ways to remove something.
    Alex Watkins - Replica
  2. Shark ION Robot R75 Side Sensor Replacement: passo 2, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 2, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 2, immagine 3 di 3
    • Be careful when removing the battery, as it will still be connected to a wire.
    • Slowly pull the white tabs outward to remove the battery.
    Make sure to review how to appropriately use special bullets. Make sure to check throughout to remove “locate” steps, and instead, just go straight to the action.
  3. Shark ION Robot R75 Side Sensor Replacement: passo 3, immagine 1 di 2 Shark ION Robot R75 Side Sensor Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Be careful when removing the connector, as the part can break if too much force is used.
    • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
    • Remove the battery from the device.
    Here, you’re using tweezers, but you don’t indicate that in the guide steps. Instead of including the information in the special bullet, I would just integrate the tool into the actual procedure. Do you have pictures of you pushing the tab? Can they yank the wire, or do they need to pull gently? I would add a flipbook style action shot to make the procedure clearer in the pictures.
  4. Shark ION Robot R75 Side Sensor Replacement, Main Brush: passo 4, immagine 1 di 1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
    I would add markup and action shots here. Which cover? Make sure to specifically identify device components.
  5. Shark ION Robot R75 Side Sensor Replacement: passo 5, immagine 1 di 1
    • Pull the main brush slightly to the right to remove it from the compartment.
    When will you know that you’ve pulled far enough to the right? When you say remove, do you need to lift the brush up? Do you have more action shots demonstrating this procedure?
    Right. Mine does not budge, and I don’t want to break the mounts.
    EiEiOh - Replica
  6. Shark ION Robot R75 Side Sensor Replacement: passo 6, immagine 1 di 2 Shark ION Robot R75 Side Sensor Replacement: passo 6, immagine 2 di 2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
    Be sure to check special bullets. Indicate how to remove the end cap.
  7. Shark ION Robot R75 Side Sensor Replacement, Side Brush: passo 7, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement, Side Brush: passo 7, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement, Side Brush: passo 7, immagine 3 di 3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
    The first step doesn’t seem necessary here. You can just include markup on the full shot to show the component you’re asking them to work on. Also, you don’t need to include cleaning/maintenance directions here, although you can include them in the introductions and/or the troubleshooting page.
  8. Shark ION Robot R75 Side Sensor Replacement, Drive Wheel Assembly: passo 8, immagine 1 di 1
    • Flip the R75 to its underside.
    • Make sure the R75 is shut off.
    • For extra security, disconnect the battery by following the prerequisite guide.
    Here, the device was already oriented this way, so the directions on the side sensor with using this prerequisite make the procedure confusing. Make sure to read through all guides to make sure you don’t have these kinds of continuity errors. Also, include the battery replacement as a prerequisite for all guides, and use the system to include the prerequisites, rather than putting this information in the note.
  9. Shark ION Robot R75 Side Sensor Replacement: passo 9, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 9, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 9, immagine 3 di 3
    • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
    • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
    • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
    Be sure to include a markup shot showing the location of the five screws. Remove locate steps in all guides. Indicate how to remove the wheel assembly in the guide text. Use caution bullets for caution notes.
    What to do when the cable rips when taking wheel out?
    Samantha Mcilwain (Sam) - Replica
  10. Shark ION Robot R75 Side Sensor Replacement: passo 10, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 10, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 10, immagine 3 di 3
    • Flip the wheel assembly over and disconnect the cable connector on its underside.
    • Remove the drive wheel assembly.
    • Repeat this process for the other side if necessary.
    Add markup. Remove all reassembly guide text. Indicate how to disconnect the cable, not just to do it.
  11. Shark ION Robot R75 Side Sensor Replacement, Shark ION Robot R75 Caster Wheel: passo 11, immagine 1 di 1
    • Orient the device with the bottom facing up.
    This photo is not helpful. Is removing the whole assembly correct procedure, or could it break the device?
  12. Shark ION Robot R75 Side Sensor Replacement: passo 12, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 12, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 12, immagine 3 di 3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
    Note that you’re using a plastic opening tool, not a screwdriver. Be sure to appropriately identify tools. Proofread all guide text for clarity and end punctuation. For all remaining “remove” steps, if something can be done in multiple ways, then you need to indicate how. Remove is good for screws because there’s only one way to do that. For everything else, use more detail or a stronger verb.
  13. Shark ION Robot R75 Side Sensor Replacement: passo 13, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 13, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 13, immagine 3 di 3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
    Hi I have the same model but the screws are not on the outside and there is what appears to be like a ring like part that held the caster assembly in the slot I cant pop the assembly back in and nor does that white part come out can you please help me with that
    Hanisha Rush - Replica
  14. Shark ION Robot R75 Side Sensor Replacement, Top Cover: passo 14, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement, Top Cover: passo 14, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement, Top Cover: passo 14, immagine 3 di 3
    • Push down on the black tab and remove the dust bin
    In the first image, the device looks significantly different for Step 13 to Step 14, then the device is flipped in the second and third images. Be careful about these kinds of continuity errors.
  15. Shark ION Robot R75 Side Sensor Replacement: passo 15, immagine 1 di 2 Shark ION Robot R75 Side Sensor Replacement: passo 15, immagine 2 di 2
    • Using a Torx TR15 screwdriver, remove the five screws from the bottom cover.
    Use markup on images to show where components are. Past Step 15, here, I’m no longer marking this issue. Additionally, proofread all steps for end punctuation.
  16. Shark ION Robot R75 Side Sensor Replacement: passo 16, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 16, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 16, immagine 3 di 3
    • Make sure the robot is facing rearward
    • Using a Torx TR15 screwdriver, remove the five screws along the front edge of the device.
    • Pull the bottom part of the bump guard away from the body of the device.
    What does it mean to face the device rearward?
    Do you have pictures of you removing the bump guard?
  17. Shark ION Robot R75 Side Sensor Replacement: passo 17, immagine 1 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 17, immagine 2 di 3 Shark ION Robot R75 Side Sensor Replacement: passo 17, immagine 3 di 3
    • Lift the top cover up from the rear of the robot to separate the top cover from the rest of the robot.
    • Be careful when separating the top from the rest of the robot, as the plastic clips can break if excessive force is applied.
    • From here, easy access to all sensors, the main brush motor, and the fan are all granted.
    What is the difference between the two black bullets? Also, the information bullet is not necessary here.
  18. Shark ION Robot R75 Side Sensor Replacement, Side Sensor: passo 18, immagine 1 di 2 Shark ION Robot R75 Side Sensor Replacement, Side Sensor: passo 18, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the screw holding down the diagonally vented side cover.
    • Slide the sensor out from the base of the robot
    Do you have pictures of the third bullet?
  19. Shark ION Robot R75 Side Sensor Replacement: passo 19, immagine 1 di 2 Shark ION Robot R75 Side Sensor Replacement: passo 19, immagine 2 di 2
    • Lift up the diagonally vented cover on the side of the robot containing the side sensor.
    How can I remove the cover?
  20. Shark ION Robot R75 Side Sensor Replacement: passo 20, immagine 1 di 2 Shark ION Robot R75 Side Sensor Replacement: passo 20, immagine 2 di 2
    • Disconnect the white connector from the sensor.
    Where is this component coming from?
  21. Shark ION Robot R75 Side Sensor Replacement: passo 21, immagine 1 di 2 Shark ION Robot R75 Side Sensor Replacement: passo 21, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the screw on the sensor.
    • Remove the sensor from its mount.
    Do you have a picture of you separating the components? Also, make sure to write directions as commands.
    where can I buy the sensor
    Karina - Replica
    And thats why i bought this robot because i don't have a man, funny i paid $300 after one year i have to work on it?? I have different Shark products and this is the first im not happy with Shark.
    Masoume A - Replica
    Yes, I agree. We have only had it less than a year and we are having problems with it already. What a joke.
    Kelly - Replica
    Less than year and I’m
    Having this issue as well very disappointing. It doesn’t say where to get the sensor .
    Sandi - Replica
Conclusione
Preparati per le riparazioni future
Acquista tutti
1Commento della guida
Curious if anyone ever saw the WiFi die in these? I cannot get the shark WiFi to show so I can add it to the network. I press both the bottoms and the icon flashes but shark WiFi never shows so the app can continue.
Shawn Winters - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 105
Tutti i Tempi: 19,301
