Salta al contenuto principale
Samsung Galaxy Note II Display Assembly Replacement
Cosa ti serve
  1. Samsung Galaxy Note II Display Assembly Replacement, Stylus: passo 1, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement, Stylus: passo 1, immagine 2 di 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Display Assembly Replacement, Rear Case: passo 2, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement, Rear Case: passo 2, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Display Assembly Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 3, immagine 3 di 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Display Assembly Replacement, MicroSD Card: passo 4, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement, MicroSD Card: passo 4, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement, MicroSD Card: passo 4, immagine 3 di 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Display Assembly Replacement, Battery: passo 5, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement, Battery: passo 5, immagine 2 di 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Display Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Display Assembly Replacement, Midframe: passo 7, immagine 1 di 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    In my phone some of the screws are litterally not ot turn - I screwed up one of the heads - be careful!
    erich zalcmann - Replica
    I have 2 note 2 phones model #: SGH-I317M. I have a broken screen that does not display in my note 2 but my brother's note 2 is working perfectly. Can I either transfer the motherboard in MY note 2 to my brothers note 2 or swap the broken screen with the new screen in my brother's note 2 ? Thanks. Reach me at anmac1789@gmail.com
    An Mac - Replica
  8. Samsung Galaxy Note II Display Assembly Replacement: passo 8, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 8, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 8, immagine 3 di 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
    I didn't have an opening tool, so I used a stiff guitar pick. Worked like a charm.
    evanjpederson - Replica
    for best result without any scratches or breaking frame, open the frame on table (solid), don't open on hand.
    Chovav Sutachy - Replica
  9. Samsung Galaxy Note II Display Assembly Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 9, immagine 3 di 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Display Assembly Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 10, immagine 2 di 2
    • Carefully pry around the corner with a plastic opening tool.
    The screen cracked using that plastic tool.
    hell0allis0n - Replica
  11. Samsung Galaxy Note II Display Assembly Replacement: passo 11, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 11, immagine 2 di 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Display Assembly Replacement: passo 12, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 12, immagine 2 di 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Display Assembly Replacement: passo 13, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 13, immagine 2 di 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
    Start with the top clip. You can see it located next to the three battery connectors. Insert the spludge from the side gently to push, the clip should go off.
    Once this clip is off, the bottom battery clip can be unclipped simply by gently moving the two pieces apart.
    anonymous 4780 - Replica
    Gan kalok bluetooth hp saya sama wifi nya nggak bisa nelusurin jaringan apa nya yg rusak apa gara gara udah di root
    aryadana55 -
    If you're primarily following the pictures, as I was, you might be frustrated that your display assembly isn't popping off. Unfortunately, a vital step was listed in the instructions but not photographed:
    "Lastly, there are two clips along the top and bottom edge of battery compartment that also hold the display assembly in place."
    alimac70117 - Replica
  14. Samsung Galaxy Note II Display Assembly Replacement: passo 14, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 14, immagine 2 di 2
    • Lift the display assembly out of the midframe.
    unblock the edge at the middle-up of the battery compart!
    Giorgio - Replica
  15. Samsung Galaxy Note II Display Assembly Replacement, Motherboard Assembly: passo 15, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement, Motherboard Assembly: passo 15, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement, Motherboard Assembly: passo 15, immagine 3 di 3
    • Use a spudger to disconnect the vibrator/power button assembly cable connector.
    • Disconnect the antenna cable connector.
    • Disconnect the display cable connector.
    Dear Sirs,
    My Galaxy Note II is completely dead due to lightning in the house. I guess there is a fuse or a protection somewhere but I can not find it. Can you help ? Thanks in advance, Jose
    Jose - Replica
    One idea would be to track backwards, i.e. check to see if current is reaching from the charge port to the mainboard. Looking at the following picture http://d3nevzfk7ii3be.cloudfront.net/igi... it seems like the fuse is - as expected - located right by the USB port. If you're lucky it could be as easy as replacing the charging board, a $10 component.
    hakro807 -
    My Note II LTE does not have the antenna cable like here
    Bubbele - Replica
  16. Samsung Galaxy Note II Display Assembly Replacement: passo 16, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 16, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 16, immagine 3 di 3
    • Disconnect the front-facing camera cable connector.
    • Disconnect the headphone jack cable connector.
    • Disconnect the digitizer cable connector.
  17. Samsung Galaxy Note II Display Assembly Replacement: passo 17, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 17, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 17, immagine 3 di 3
    • Use the spudger to disconnect the antenna cable connector from the motherboard.
    • Disconnect the soft button cable connector.
    • Disconnect the USB board cable connector.
  18. Samsung Galaxy Note II Display Assembly Replacement: passo 18, immagine 1 di 1
    • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
    Is it possible to replace my Note II N7105 motherboard to N7100? Is there some negative effects happen, if i did it?
    Eduardo Lucas III - Replica
  19. Samsung Galaxy Note II Display Assembly Replacement: passo 19, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 19, immagine 2 di 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  20. Samsung Galaxy Note II Display Assembly Replacement, Headphone Jack/Earpiece Speaker Assembly: passo 20, immagine 1 di 1
    • Remove the 3 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
  21. Samsung Galaxy Note II Display Assembly Replacement: passo 21, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 21, immagine 2 di 2
    • Grasp the headphone jack portion of the assembly and lift it out of its groove in the display assembly.
  22. Samsung Galaxy Note II Display Assembly Replacement: passo 22, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 22, immagine 2 di 2
    • Gently pull the headphone jack straight up without twisting the cable to remove the earpiece speaker portion from its recess.
    • Twisting or pulling unevenly could damage the cable. Be very careful as you extract the assembly.
  23. Samsung Galaxy Note II Display Assembly Replacement, Display Assembly: passo 23, immagine 1 di 1
    • Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
  24. Samsung Galaxy Note II Display Assembly Replacement: passo 24, immagine 1 di 1
    • Remove the front-facing camera bracket.
  25. Samsung Galaxy Note II Display Assembly Replacement: passo 25, immagine 1 di 1
    • Remove the front-facing camera.
  26. Samsung Galaxy Note II Display Assembly Replacement: passo 26, immagine 1 di 1
    • Remove the 3 mm Phillips #00 screw securing the antenna board to the display assembly.
  27. Samsung Galaxy Note II Display Assembly Replacement: passo 27, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 27, immagine 2 di 2
    • Insert the tip of a spudger under the antenna board to free it from the adhesive holding it to the display assembly.
  28. Samsung Galaxy Note II Display Assembly Replacement: passo 28, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 28, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 28, immagine 3 di 3
    • Gently de-route the antenna cable from its channel in the display assembly.
  29. Samsung Galaxy Note II Display Assembly Replacement: passo 29, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 29, immagine 2 di 2
    • Remove the antenna cable from the display assembly.
    • When reassembling your device, install the USB board and attach the antenna connector before routing it into the channel. This will ensure the proper placement of the antenna cable connectors.
  30. Samsung Galaxy Note II Display Assembly Replacement: passo 30, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 30, immagine 2 di 2
    • Insert the tip of a spudger under the vibrator to free it from the adhesive holding it to the display assembly.
    • Do not attempt to remove the vibrator entirely as it is still attached to the vibrator/power button assembly.
  31. Samsung Galaxy Note II Display Assembly Replacement: passo 31, immagine 1 di 2 Samsung Galaxy Note II Display Assembly Replacement: passo 31, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to detach the power button from the adhesive securing it to the display assembly.
    • Remove the vibrator/power button assembly from the display assembly.
  32. Samsung Galaxy Note II Display Assembly Replacement: passo 32, immagine 1 di 1
    • Remove the 3 mm Phillips #00 from the speaker enclosure.
  33. Samsung Galaxy Note II Display Assembly Replacement: passo 33, immagine 1 di 1
    • Remove the speaker enclosure.
  34. Samsung Galaxy Note II Display Assembly Replacement: passo 34, immagine 1 di 1
    • Use the flat end of a spudger to disconnect the antenna cable connector from the USB board.
  35. Samsung Galaxy Note II Display Assembly Replacement: passo 35, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 35, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 35, immagine 3 di 3
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
    • Remove the USB board from the display assembly.
  36. Samsung Galaxy Note II Display Assembly Replacement: passo 36, immagine 1 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 36, immagine 2 di 3 Samsung Galaxy Note II Display Assembly Replacement: passo 36, immagine 3 di 3
    • Gently deroute the antenna cable from its notch in the display assembly.
    • Remove the antenna cable.
Conclusione
Altre 183 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
472.708 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
120 Membri
20.862 Guide realizzate
12Commenti sulla guida
This guide is awful. Not even the US phone model. mine and most on youtube does not have the antennae on both side, only a antena on one of the sides of the phone.
Also this does not cover how to remove most things that you HAVE to remove when you buy the digitizer+lcd from here... not to mention that it stops in the middle...
there is a video on youtube from https://www.youtube.com/user/LE55ONS that shows how to dismantle the note2 in much more detail than this... and he goes all the way and show how to remove every piece needed.
gcb - Replica
thx for the video!
note i was repairing looked slightly different. no antenna on the left and powerbutton/vibrator where differnet parts, midframe is hold by 2 additional tabs inside battery compartment. video was a good addition to this guid, and helped alot ;)
Lego -
Thank you for the link to the videos, it helped particularly for the vibrator and power button.
anonymous 4780 -
This is the Sprint model, SPH-L900. It's not his fault that your phone is different.
Roger -
This guide showed me how to take mine apart in ten minutes every step was included in this guide...dont know what phone you have^^^^but this is a great guide
chad - Replica
Overall, a great guide to look at while you are fixing the Note II. However, it misses couple of tips. It forgot to mention to remove earphone jack underneath the motherboard and caution about plastic clip at center back when you are lifting display from midframe at Step 14. I would recommend supplementing this guide with youtube video of disassembling Note II before you go ahead and fix your phone.
I thank author and editor(s) for posting this guide and helping me successfully repair my Note II.
longshot022singon - Replica
I'm just wondering as I'm not to good with this stuff but if I was to do this would I be able to do the above and put back onto a new screen and keep my phones data pics ect if not then how would I go about it any ideas ??
Steve Smith - Replica
There seems to be an issue with the screen replacement proposed with the guide, they don't match. I ordered the screen replacement (Display assembly LCD) for my Note 2. My phone is a N7100 (international 3G model) and the replacement came labelled for N7105 (4G/LTE model). There is a difference in the clipping path for the antenna cable travelling from botton to top: the path is longer and exits on the external side of the motherboard instead of the internal side.The antenna cable can thus not be plugged back on the N7100 model.
As the LCD assembly pieces labelled with the phone model are "not for sale", you have to match your model with either the one sold by AT&T or the one sold by Verizon. It looks like the AT&T LCD is for the LTE (N7105) devices only....
Is this a part from iFixit?
Scott Dingle -
At&t Gsm and sprint verizon cdma lte the are diffrent
Daniel ONeal - Replica
ok ya the guide is a little out of date or not for U.S. phone but with the layout being basicly the same and if your not a complete moron you can firgure it out like i did and i did watch youtube just to see how long it would take....1 step i suggest is the you make sure the headphone jack rubber is on correctly or you cant you it use it and have to take it apart again
nmmicadet14 - Replica
My note 2 display has been damaged so you any have old diaplay... Then msg me or call on 887150
1053 nd I buy nd pay for this
Pankaj kumar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 49
Tutti i Tempi: 310,181
