Salta al contenuto principale
RCA 10 Viking Pro RCT6K03W13 Battery Replacement
Ryan Wickett
Ryan Wickett e 2 altri collaboratori
Ultimo aggiornamento il January 2, 2020
10 minuti
Moderato
Necessarie Immagini Migliori
Introduzione Migliore
Introduzione
Vai al passo 1
This guide will talk you through the process of replacing the battery in your RCA 10 Viking Pro RCT6K03W13.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
  1. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: passo 1, immagine 1 di 3 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: passo 1, immagine 2 di 3 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: passo 1, immagine 3 di 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 2, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 3, immagine 1 di 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 4, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 4, immagine 2 di 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 6, immagine 1 di 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 7, immagine 1 di 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 8, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 8, immagine 2 di 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 9, immagine 1 di 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 9, immagine 2 di 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
Conclusione
Altre 5 persone hanno completato questa guida.
Ryan Wickett
Membro da: 10/25/19
632 Reputazione
3 Guide realizzate
4Commenti sulla guida
Where can I get the battery for this?
Justin - Replica
You can get a battery from Amazon or Walmart.com your wellcome ?
GLENDA Vandergrift -
How much voltage should the battery put out in order for the tablet to turn on?
Jesus Rios - Replica
How much
How much
jennylyne_08 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 42
Tutti i Tempi: 3,356
