Philips Satinelle Tweezer Replacement
Introduzione
Vai al passo 1If the tweezers are struggling to grasp and pull out hair, it's time to replace them. Replacing the blades only requires you to disassemble the head of the epilator. You will only need a plastic opening tool or some other prying tool. Be careful when removing the tension clip. It has a tendency to shoot out at high speed when removed. This guide generally takes one to three minutes to complete.
Cosa ti serve
Strumenti
Altre 2 persone hanno completato questa guida.
