Philips Norelco Shaver Head Blade Replacement
Introduzione
Vai al passo 1If you have a Philips Norleco face shaver and are noticing that it is becoming less effective, you may need to replace the shaving head blades with new ones. These heads contain small blades that dull over time. Philips Norelco recommends they be replaced every 12 months. In this guide I will show you how to install your new replacement blades.
Begin by pressing the small button beneath the head to allow it to open.
Altre 16 persone hanno completato questa guida.
9 Commenti
The only problem I had was to insert the hinge into the body. Didn't want to push too hard as I was worried I could snap off some plastic parts. Once I had pushed the OLD unit on and off a couple of times the new one went in quite easily ( although the old unit was much more free than the new unit). Many thanks for your instructions - most useful!
Mike L. 14 March 2022
How do you change the trimmer blade on back of it ? Or can you ?
Clear and simple tutorial. Excellent!
