Salta al contenuto principale
Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement
August Post
August Post e un altro collaboratore
Ultimo aggiornamento il July 15, 2024
10 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show how to take out both trimmer blades, and replace them with a new ones. You may need this if the trimmer blades on the Philips Norelco Bodygroom break, or for some reason become too dull to use. It is also necessary for this guide to show how to disassemble and reassemble the trimmer head in order to get to the blades. It is recommended to have the iFixit Pro Tech Toolkit since it will contain all tools necessary for this guide. Lastly, you will need to provide your own working blades to replace the broken ones.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  1. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement, Trimmer Head Blades: passo 1, immagine 1 di 2 Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement, Trimmer Head Blades: passo 1, immagine 2 di 2
    • Pop open the trimmer head by pushing against the blades.
    • Slide off trimmer guard and open the hatch on the side.
    • Remove the trimmer from the base.
  2. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement: passo 2, immagine 1 di 2 Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement: passo 2, immagine 2 di 2
    • Remove spring first, and then pull off white plastic along with the first, moving blade.
    • Use spudger to pry off second, stationary blade.
Conclusione
August Post
Membro da: 11/07/17
415 Reputazione
3 Guide realizzate
IUPUI, Team S2-G4, Harley Fall 2017 Membro di IUPUI, Team S2-G4, Harley Fall 2017
IUPUI-HARLEY-F17S2G4
3 Membri
7 Guide realizzate
Un commento
How do you reattach the spring?
Antonio Chrysokhou - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 41
Tutti i Tempi: 3,826
