Salta al contenuto principale
Oral-B Black 7000 Induction Coil Replacement
Rachel Surridge
Rachel Surridge e 6 altri collaboratori
Ultimo aggiornamento il May 8, 2024
15 - 30 minuti
Difficile
Introduzione
Vai al passo 1
The induction charging coil allows the device to receive power from the supplied charging base. It will need to be replaced if it is damaged by use or by external conditions. This guide describes how to replace the induction charging coil. Some steps in this procedure require desoldering connections. For a review of soldering techniques, check out this How to Solder Guide.
Cosa ti serve
Strumenti
Mostra di più…
  1. Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: passo 1, immagine 1 di 3 Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: passo 1, immagine 2 di 3 Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: passo 1, immagine 3 di 3
    • Use the charging station to remove the a small plastic plug from the end of the toothbrush by inserting the charging station into the end insert and twisting counter-clockwise by 90 degrees.
  2. Oral-B Black 7000 Induction Coil Replacement: passo 2, immagine 1 di 1
    • Remove the end cap from the bottom of the toothbrush by prying it off with a spudger.
  3. Oral-B Black 7000 Induction Coil Replacement: passo 3, immagine 1 di 1
    • Remove the top cap by using a spudger to pry the plastic ring off of the toothbrush frame.
  4. Oral-B Black 7000 Induction Coil Replacement: passo 4, immagine 1 di 2 Oral-B Black 7000 Induction Coil Replacement: passo 4, immagine 2 di 2
    • Use a spudger to loosen the two plastic tabs next to the induction coil that secure the internal assembly to the frame.
    • Push on the rotating head in order to pop the assembly out of the black plastic casing.
    • You can also use a spudger to leverage the assembly out, but this may break the copper wire connected to the induction coil, so be careful.
    You need to release the induction coil’s plastic clips before you try to slide it out! This is a key missing step.
    Matthew Dowdeswell - Replica
    I agree with Matthew. You must insert a spudger and release the plastic clips while pressing down on the rotating head. I held the rotating head with a pair of pliars and then released the plastic clips and it popped right out.
    Brian Davis -
    i third that, this needs to be added ASAP, you have no chance of getting it out without unclicking those two latches that lock the inner assembly to the outer casing.
    Rainer Joos - Replica
    I'd recommend changing this to say where these tabs are. Basically, you insert the spudger between the left and right side plastic arms/tabs going to the coil assembly and the body. If you have light pressure applied to the head at the right time, you'll feel them move when you insert a spudger and put a tiny bit of leverage.
    Ryan Novosielski - Replica
    You can see these tabs most easily in step 7. The tab shown in the second photo doesn't really have anything to do with anything (maybe that's the ill-advised leverage method).
  5. Oral-B Black 7000 Induction Coil Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Unwrap the ends of the wires from the white plastic pegs using a pair of tweezers.
    • Each wire end is wrapped around the peg 3-4 times.
    Unnecessary step for battery replacement! The electrode of the battery is solely the single solder point in the middle and the battery comes out just as well if you just leave the coil. If all you want is to replace the battery. just leave the coil, It’s fiddly and risky to break the wire and more work, only disadvantages. Good efforts!
    I'm not doing this right now, but thank you!
    Ryan Novosielski -
    Achtung dieser Schritt ist für den reinen Akkutausch unnötig und quasi falsch! Die Spule kann verbleiben, der Akku ist einzig die einzelne mittige Lötstelle!
  6. Oral-B Black 7000 Induction Coil Replacement: passo 6, immagine 1 di 1
    • Melt the solder at the two pads on either side of the top of the motherboard. This will require a high heat soldering iron. Remove the wire from the solder pads using tweezers once the solder melts.
  7. Oral-B Black 7000 Induction Coil Replacement: passo 7, immagine 1 di 1
    • Remove the induction coil by pulling the plastic tabs out of their keepers.
    • A spudger can be used to remove the plastic tabs from their keepers if neccessary.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S1-G1, Harley Fall 2017 Membro di IUPUI, Team S1-G1, Harley Fall 2017
IUPUI-HARLEY-F17S1G1
3 Membri
16 Guide realizzate
3 Commenti
bonjour, ou puis je trouver une nouvelle bobine d’induction ou puis je remplacer simplement le fil de cuivre
Geoffrey Sacré - Replica
juste une précision pour sortir l’intérieur de la brosse du manche il faut appuyez sur les deux pattes plastique en bas près de la boucle d’induction
on voit une des pattes a l’étape 5
Woher bekomme ich denn eine neue ladespule?
Franz Leichsenring - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 168
Tutti i Tempi: 6,017
