Salta al contenuto principale
Oontz Angle 3 ULTRA Micro USB Port Replacement
Ian
Ian e 2 altri collaboratori
Ultimo aggiornamento il May 7, 2024
30 minuti
Molto difficile
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
If your Oontz Angle 3 ULTRA speaker is not charging or connecting to external devices, you may need to replace your speaker’s Micro USB port. This replacement guide will walk you through replacing the Micro USB port of your Oontz Angle 3 ULTRA Bluetooth speaker. For this guide, you will need a spudger, a Soldering Iron with Solder Wick or a Solder Sucker, and tweezers. Follow this guide to learn how to solder and de-solder connections. Come saldare e dissaldare componenti elettrici
Cosa ti serve
Strumenti
Mostra di più…
  1. Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: passo 1, immagine 1 di 3 Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: passo 1, immagine 2 di 3 Oontz Angle 3 ULTRA Micro USB Port Replacement, Back Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 2, immagine 1 di 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 2, immagine 2 di 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 2, immagine 3 di 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 3, immagine 1 di 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 3, immagine 2 di 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 3, immagine 3 di 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 4, immagine 1 di 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 4, immagine 2 di 3 Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 4, immagine 3 di 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
    Where can I get the mother board and other parts to buy for the Oontz angel 3 please
    Christopher Dunkley - Replica
  5. Oontz Angle 3 ULTRA Micro USB Port Replacement, Micro USB Port: passo 5, immagine 1 di 1
    • Gently push the ports away from the speaker enclosure with the spudger to free the motherboard.
  6. Oontz Angle 3 ULTRA Micro USB Port Replacement: passo 6, immagine 1 di 1
    Please tell us who makes the MICRO USB CONNECTOR that we are attempting to replace?
    MFG NAME:
    MFG PN:
    Steve Michalski - Replica
Conclusione
3Commenti sulla guida
These instructions are great, but they're useless unless you can find a replacement micro USB port… Any suggestions? Because I couldn't find one online that indicated it was compatible with the OontZ…
mango - Replica
Couldn't find proper exact port... so just removed old port from board with dykes, used a junk usb cable and directly soldered the + and - leads of cable to circuit board. ( removed mic at top ( didn't use it )) and fed cable thru mic hole out ( hot glue on inside so cable doesn't pull ).... now speaker has a 6" tail for charging.
Works as good as new, no issue charging.
TJ Mac -
They are on ebay, just have to take time and have tools to install, im gonna do it soon to mine...
https://www.ebay.com/itm/264318826857?va...
W S - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 49
Tutti i Tempi: 3,083
