Salta al contenuto principale
Oontz Angle 3 ULTRA  Battery Replacement
Noah Plaza
Noah Plaza e un altro collaboratore
Ultimo aggiornamento il June 3, 2020
10 - 20 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
If your device is not charging properly or not turning on at all, it may be time to replace the battery in your device. This guide will illustrate the steps that you will need to take in order to replace the battery in your Oontz Angle 3 ULTRA. Soldering is a necessary skill to complete this guide, so please read the How to Solder and Desolder Connections Guide for more information.
Cosa ti serve
Strumenti
Mostra di più…
  1. Oontz Angle 3 ULTRA  Battery Replacement, Back Panel: passo 1, immagine 1 di 3 Oontz Angle 3 ULTRA  Battery Replacement, Back Panel: passo 1, immagine 2 di 3 Oontz Angle 3 ULTRA  Battery Replacement, Back Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA  Battery Replacement: passo 2, immagine 1 di 3 Oontz Angle 3 ULTRA  Battery Replacement: passo 2, immagine 2 di 3 Oontz Angle 3 ULTRA  Battery Replacement: passo 2, immagine 3 di 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA  Battery Replacement: passo 3, immagine 1 di 3 Oontz Angle 3 ULTRA  Battery Replacement: passo 3, immagine 2 di 3 Oontz Angle 3 ULTRA  Battery Replacement: passo 3, immagine 3 di 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA  Battery Replacement: passo 4, immagine 1 di 3 Oontz Angle 3 ULTRA  Battery Replacement: passo 4, immagine 2 di 3 Oontz Angle 3 ULTRA  Battery Replacement: passo 4, immagine 3 di 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
    Where can I get the mother board and other parts to buy for the Oontz angel 3 please
    Christopher Dunkley - Replica
  5. Oontz Angle 3 ULTRA  Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Make sure that the device is OFF before operating here, as an electrical spark may occur if the device is operating.
    • Once the motherboard is exposed after disassembly, follow the thick black and red cords from the battery pack to their attachments to the board.
    • Use the soldering iron to melt the positive and negative connections.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections Guide.
  6. Oontz Angle 3 ULTRA  Battery Replacement: passo 6, immagine 1 di 1
    • After you have disconnected the battery from the motherboard, use a box cutter or exacto knife to carefully cut the blue wrapping around the battery.
    • Aligning the edge of the knife tangent to the battery works best for avoiding a cut to the electrolyte itself.
    • Please take extreme caution with this step. You may remove the blue tape with another method but if you do use an exacto knife, please do not cut into the battery.
  7. Oontz Angle 3 ULTRA  Battery Replacement: passo 7, immagine 1 di 1
    • Once cut, it should require no more than your fingers to peel away the blue wrapping around the battery, and expose the terminal.
  8. Oontz Angle 3 ULTRA  Battery Replacement: passo 8, immagine 1 di 1
    • Finally, use the soldering Iron on the two terminals of the battery connection to disconnect it from the wire.
    • To reconnect the battery, solder the two terminal connections, or use the replacement battery's wires to reattach to the motherboard
Conclusione
2Commenti sulla guida
Could you please provide a source / part # for the replacement battery?
Is it just two 18650 style 3.7 Volt lithium batteries in series or parallel?
Alex - Replica
Was able to narrow down the issue to the board using a known good 18650 battery. Also have seen a couple forum posts saying it’s the board that goes bad on some of these units. Now I’m starting to wonder if it’s just a bad capacitor or something replaceable with a standard soldering iron…
Alex -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 2,777
