Salta al contenuto principale
OnePlus Nord 2 5G Battery Replacement
Cosa ti serve
  1. OnePlus Nord 2 5G Battery Replacement, Loosen the rear glass: passo 1, immagine 1 di 1
    • Prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. OnePlus Nord 2 5G Battery Replacement, Insert an iFlex: passo 2, immagine 1 di 3 OnePlus Nord 2 5G Battery Replacement, Insert an iFlex: passo 2, immagine 2 di 3 OnePlus Nord 2 5G Battery Replacement, Insert an iFlex: passo 2, immagine 3 di 3
    • Due to its surface, no suction tool will hold onto the phone's rear glass. A thin slicing tool is required to create a gap between the rear glass and the midframe.
    • Insert an iFlex into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap. This may require some force.
    • Leave the iFlex in place to prevent the adhesive from resealing.
  3. OnePlus Nord 2 5G Battery Replacement, Insert an opening pick: passo 3, immagine 1 di 3 OnePlus Nord 2 5G Battery Replacement, Insert an opening pick: passo 3, immagine 2 di 3 OnePlus Nord 2 5G Battery Replacement, Insert an opening pick: passo 3, immagine 3 di 3
    • Insert an opening pick into the gap you created with the iFlex.
    • Remove the iFlex.
  4. OnePlus Nord 2 5G Battery Replacement, Slice the bottom edge adhesive: passo 4, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Slice the bottom edge adhesive: passo 4, immagine 2 di 2
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. OnePlus Nord 2 5G Battery Replacement: passo 5, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement: passo 5, immagine 2 di 2
    • Insert a second opening pick at the bottom right corner of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  6. OnePlus Nord 2 5G Battery Replacement, Slice the left edge adhesive: passo 6, immagine 1 di 3 OnePlus Nord 2 5G Battery Replacement, Slice the left edge adhesive: passo 6, immagine 2 di 3 OnePlus Nord 2 5G Battery Replacement, Slice the left edge adhesive: passo 6, immagine 3 di 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. OnePlus Nord 2 5G Battery Replacement, Slice the top edge adhesive: passo 7, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Slice the top edge adhesive: passo 7, immagine 2 di 2
    • Insert a fourth opening pick underneath the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  8. OnePlus Nord 2 5G Battery Replacement, Slice the right edge adhesive: passo 8, immagine 1 di 3 OnePlus Nord 2 5G Battery Replacement, Slice the right edge adhesive: passo 8, immagine 2 di 3 OnePlus Nord 2 5G Battery Replacement, Slice the right edge adhesive: passo 8, immagine 3 di 3
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  9. OnePlus Nord 2 5G Battery Replacement, Remove the back cover: passo 9, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Remove the back cover: passo 9, immagine 2 di 2
    • Remove the back cover.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  10. OnePlus Nord 2 5G Battery Replacement, Remove the connector bracket: passo 10, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Remove the connector bracket: passo 10, immagine 2 di 2
    • Use a pair of tweezers to remove the metal bracket covering the flash assembly connector.
  11. OnePlus Nord 2 5G Battery Replacement, Disconnect the flash assembly: passo 11, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Disconnect the flash assembly: passo 11, immagine 2 di 2
    • Use the point of a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
  12. OnePlus Nord 2 5G Battery Replacement, Unfasten the motherboard cover: passo 12, immagine 1 di 1
    • Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
  13. OnePlus Nord 2 5G Battery Replacement, Pry up the motherboard cover: passo 13, immagine 1 di 3 OnePlus Nord 2 5G Battery Replacement, Pry up the motherboard cover: passo 13, immagine 2 di 3 OnePlus Nord 2 5G Battery Replacement, Pry up the motherboard cover: passo 13, immagine 3 di 3
    • The motherboard cover is held in place by plastic clips.
    • Insert an opening pick underneath the bottom right edge of the motherboard cover.
    • Twist the opening pick sideways release the plastic clips and to pry up the motherboard cover.
  14. OnePlus Nord 2 5G Battery Replacement, Remove the motherboard cover: passo 14, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Remove the motherboard cover: passo 14, immagine 2 di 2
    • Remove the motherboard cover.
  15. OnePlus Nord 2 5G Battery Replacement, Disconnect the battery cable: passo 15, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Disconnect the battery cable: passo 15, immagine 2 di 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  16. OnePlus Nord 2 5G Battery Replacement, Unfasten the daughterboard cover: passo 16, immagine 1 di 1
    • Removing the daughterboard cover isn't mandatory to replace the battery. However, doing so reduces the risk of damaging surrounding components.
    • Use a Phillips screwdriver to remove the six 3.8 mm-long screws securing the daugtherboard cover.
  17. OnePlus Nord 2 5G Battery Replacement, Pry up the daughterboard cover: passo 17, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Pry up the daughterboard cover: passo 17, immagine 2 di 2
    • Insert the point of a spudger underneath the top right edge of the daughterboard cover.
    • Pry upwards to loosen the daughterboard cover.
    • Don't try to remove the daughterboard cover all the way yet. It's still adhered to the loudspeaker.
  18. OnePlus Nord 2 5G Battery Replacement, Remove the daughterboard cover: passo 18, immagine 1 di 3 OnePlus Nord 2 5G Battery Replacement, Remove the daughterboard cover: passo 18, immagine 2 di 3 OnePlus Nord 2 5G Battery Replacement, Remove the daughterboard cover: passo 18, immagine 3 di 3
    • Fold the daughterboard cover to the left like you would open the front cover of a book.
    • Carefully peel the black tape off of the loudspeaker.
    • Remove the daughterboard cover.
  19. OnePlus Nord 2 5G Battery Replacement, Peel up the right pull tab: passo 19, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Peel up the right pull tab: passo 19, immagine 2 di 2
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use a pair of blunt nose tweezers or your fingers to peel the right pull tab off the battery.
  20. OnePlus Nord 2 5G Battery Replacement, Lift the right half of the battery: passo 20, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Lift the right half of the battery: passo 20, immagine 2 di 2
    • Grab and lift the right pull-tab to remove the first half of the battery from its recess.
    • Don't try to remove the battery all the way yet. The left half is still adhered to the midframe.
    • If you're having trouble lifting the battery out of its recess, apply a heated iOpener to the screen for two minutes to loosen the battery adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    • Only apply heat to the screen to prevent the battery from overheating.
  21. OnePlus Nord 2 5G Battery Replacement, Peel up the left pull tab: passo 21, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Peel up the left pull tab: passo 21, immagine 2 di 2
    • Use a pair of blunt nose tweezers or your fingers to peel the left pull tab off the battery.
  22. OnePlus Nord 2 5G Battery Replacement, Lift the left half of the battery: passo 22, immagine 1 di 2 OnePlus Nord 2 5G Battery Replacement, Lift the left half of the battery: passo 22, immagine 2 di 2
    • Grab and lift the left pull-tab to remove the second half of the battery from its recess.
  23. OnePlus Nord 2 5G Battery Replacement, Remove the battery: passo 23, immagine 1 di 3 OnePlus Nord 2 5G Battery Replacement, Remove the battery: passo 23, immagine 2 di 3 OnePlus Nord 2 5G Battery Replacement, Remove the battery: passo 23, immagine 3 di 3
    • Peel the battery from any remaining adhesive and remove it.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard before you press it into place to ensure correct alignment. Disconnect the battery after it's seated.
Conclusione
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our OnePlus Nord 2 5G answers community for help.
Altre 3 persone hanno completato questa guida.
Dominik Schnabelrauch
Membro da: 11/23/16
204.166 Reputazione
682 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.218 Guide realizzate
Un commento
Hi. Please tell me, what is the name of the original battery for the nord2 model? Which battery should I change to?
Peter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 102
Ultimi 30 Giorni: 487
Tutti i Tempi: 4,931
