Salta al contenuto principale
Nothing Phone (1) Charging Port Replacement
Cosa ti serve
  1. Nothing Phone (1) Charging Port Replacement, Heat the rear glass: passo 1, immagine 1 di 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Nothing Phone (1) Charging Port Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Nothing Phone (1) Charging Port Replacement, Slice the adhesive: passo 3, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Slice the adhesive: passo 3, immagine 2 di 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Nothing Phone (1) Charging Port Replacement, Slice the adhesive: passo 4, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Slice the adhesive: passo 4, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Slice the adhesive: passo 4, immagine 3 di 3
    • When you slice near the glyph, insert only the tip of the opening pick (~2-3 mm) to avoid damaging the LEDs.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Nothing Phone (1) Charging Port Replacement: passo 5, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement: passo 5, immagine 2 di 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Nothing Phone (1) Charging Port Replacement: passo 6, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement: passo 6, immagine 2 di 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
  7. Nothing Phone (1) Charging Port Replacement, Remove the rear glass: passo 7, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Remove the rear glass: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Dust Blower
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Since the rear glass of the Nothing Phone (1) is transparent a dust blower may come in handy for cleaning before installing a new rear glass.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Nothing Phone (1) Charging Port Replacement, Remove the plastic cover: passo 8, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the plastic cover: passo 8, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the plastic cover: passo 8, immagine 3 di 3
    • The plastic covering the earpiece speaker is held in place by mild adhesive. If you're having a hard time removing it, apply a heated iOpener for 1-2 minutes to loosen the adhesive underneath.
    • Insert an opening pick underneath the grey plastic cover at the top edge of your phone.
    • Use your opening pick to pry up the plastic cover.
    • Remove the plastic cover.
  9. Nothing Phone (1) Charging Port Replacement, Unfasten the earpiece speaker screws: passo 9, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the earpiece speaker.
  10. Nothing Phone (1) Charging Port Replacement, Remove the earpiece speaker: passo 10, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the earpiece speaker: passo 10, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the earpiece speaker: passo 10, immagine 3 di 3
    • Insert the flat end of a spudger underneath the bottom edge of the earpiece speaker.
    • Use your spudger to pry up the earpiece speaker.
    • Use a pair of tweezers or your fingers to remove the earpiece speaker.
  11. Nothing Phone (1) Charging Port Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 3 di 3
    • Use a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
    • Use a spudger to disconnect the LED glyph cable by prying the connector straight up from its socket.
  12. Nothing Phone (1) Charging Port Replacement, Remove the recording indicator light cover: passo 12, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the recording indicator light cover: passo 12, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the recording indicator light cover: passo 12, immagine 3 di 3
    • Insert an opening pick underneath the recording indicator light cover at the top right corner of the screen.
    • Use a pair of tweezers or your fingers to remove the recording indicator light cover.
  13. Nothing Phone (1) Charging Port Replacement, Unfasten the motherboard cover screws: passo 13, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the four 4.2 mm-long screws securing the motherboard cover.
  14. Nothing Phone (1) Charging Port Replacement, Unfasten the daughterboard screws: passo 14, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the four 4.2 mm-long screws securing the daughterboard cover.
  15. Nothing Phone (1) Charging Port Replacement, Remove the bottom LED glyph assembly: passo 15, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the bottom LED glyph assembly: passo 15, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the bottom LED glyph assembly: passo 15, immagine 3 di 3
    • Be very careful when working on the bottom LED assembly. There's a cable running underneath its whole surface that can be damaged easily.
    • The bottom LED assembly is held in place by small pieces of adhesive.
    • Slide an opening pick underneath the right, bottom and left edge of the bottom LED assembly to carefully separate it from the daughterboard cover.
    • Do not slide the opening pick deeper than shown in the photos. Otherwise you risk damaging the LED cable.
  16. Nothing Phone (1) Charging Port Replacement, Fold over the bottom LED assembly: passo 16, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Fold over the bottom LED assembly: passo 16, immagine 2 di 2
    • The bottom LED assembly is still held in place by a small piece of adhesive sitting between the cable winds. Avoid straining or tearing the cable when folding the assembly over.
    • Use a pair of blunt nosed tweezers and carefully fold the bottom LED assembly over to get free access to the LED cable connector.
  17. Nothing Phone (1) Charging Port Replacement, Open the connector bracket: passo 17, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Open the connector bracket: passo 17, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Open the connector bracket: passo 17, immagine 3 di 3
    • The LED connector bracket sits very tight and may require some force to open it.
    • Insert one arm of a pair of tweezers into the gap at the right side of the connector bracket.
    • Push your tweezers toward the left edge of the phone to free the closure flap of the connector bracket.
    • If you're struggling to free the flap, pull the black rubber piece to the left to give the bracket more room.
    • Lift the connector bracket with your tweezers to access the LED connector.
  18. Nothing Phone (1) Charging Port Replacement, Disconnect the LED cable: passo 18, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Disconnect the LED cable: passo 18, immagine 2 di 2
    • Use a spudger to disconnect the LED cable by prying the connector straight up from its socket.
  19. Nothing Phone (1) Charging Port Replacement, Remove the bottom LED assembly: passo 19, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Remove the bottom LED assembly: passo 19, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the bottom LED assembly.
  20. Nothing Phone (1) Charging Port Replacement, Unfasten the daughterboard cover screws: passo 20, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the five 4.2 mm-long screws securing the daughterboard cover
  21. Nothing Phone (1) Charging Port Replacement, Remove the plastic shield: passo 21, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Remove the plastic shield: passo 21, immagine 2 di 2
    • The grey plastic shield on top of the daughterboard cover is held in place by mild adhesive.
    • Use a pair of tweezers to carefully separate the grey plastic shield from the daughterboard cover and remove it.
  22. Nothing Phone (1) Charging Port Replacement, Fingerprint cable information: passo 22, immagine 1 di 1
    • When prying up the daughterboard cover in the following step be very careful and avoid levering with too much force or to press your prying tool too deep underneath the cover. Otherwise, the fingerprint cable running underneath can be easily torn.
  23. Nothing Phone (1) Charging Port Replacement, Pry up the daughterboard cover: passo 23, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Pry up the daughterboard cover: passo 23, immagine 2 di 2
    • Insert the pointed end of a spudger underneath the top edge of the daughterboard cover just above the black rubber guard securing the LED connector bracket.
    • Pry up with the spudger to release the daughterboard cover from its clips.
  24. Nothing Phone (1) Charging Port Replacement, Remove the daughterboard cover: passo 24, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Remove the daughterboard cover: passo 24, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the daughterboard cover.
  25. Nothing Phone (1) Charging Port Replacement, Remove the black rubber guard: passo 25, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Remove the black rubber guard: passo 25, immagine 2 di 2
    • Use a pair of tweezers to remove the black rubber guard securing the LED connector bracket.
  26. Nothing Phone (1) Charging Port Replacement, Remove the connector bracket: passo 26, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Remove the connector bracket: passo 26, immagine 2 di 2
    • Use a pair of tweezers to remove the LED connector bracket.
  27. Nothing Phone (1) Charging Port Replacement, Disconnect the interconnect cable: passo 27, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Disconnect the interconnect cable: passo 27, immagine 2 di 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  28. Nothing Phone (1) Charging Port Replacement, Separate the interconnect cable adhesive: passo 28, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Separate the interconnect cable adhesive: passo 28, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Separate the interconnect cable adhesive: passo 28, immagine 3 di 3
    • The interconnect cable is held in place by mild adhesive.
    • Carefully slide an opening pick underneath the interconnect cable to separate it from the charging coil assembly and the loudspeaker.
  29. Nothing Phone (1) Charging Port Replacement, Fold over the interconnect cable: passo 29, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Fold over the interconnect cable: passo 29, immagine 2 di 2
    • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
    • Use a pair of tweezers to fold the interconnect cable to the left like you'd open the cover of a book.
  30. Nothing Phone (1) Charging Port Replacement, Separate the wireless charging coil adhesive: passo 30, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Separate the wireless charging coil adhesive: passo 30, immagine 2 di 2
    • The charging coil assembly is held in place by mild adhesive.
    • Insert an opening pick underneath the bottom right edge of the charging coil assembly.
    • Slide the opening along the right edge of the charging coil assembly to separate the adhesive.
  31. Nothing Phone (1) Charging Port Replacement: passo 31, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement: passo 31, immagine 2 di 2
    • Insert an opening pick underneath the bottom left edge of the charging coil assembly.
    • Slide the opening along the left edge of the charging coil assembly to separate the adhesive.
  32. Nothing Phone (1) Charging Port Replacement, Fold over the charging board assembly: passo 32, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Fold over the charging board assembly: passo 32, immagine 2 di 2
    • When folding the charging coil assembly over avoid straining components and cables.
    • Carefully fold the charging coil to the top edge of the phone to access the motherboard cover screws.
  33. Nothing Phone (1) Charging Port Replacement, Unfasten the motherboard cover screws: passo 33, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three 4.2 mm-long screws securing the motherboard cover.
  34. Nothing Phone (1) Charging Port Replacement, Separate the camera cover and flash assembly: passo 34, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Separate the camera cover and flash assembly: passo 34, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Separate the camera cover and flash assembly: passo 34, immagine 3 di 3
    • Return the charging coil to its original position.
    • Don't try to remove the camera cover and flash assembly all the way. Its cable runs underneath the motherboard cover and is very fragile.
    • Carefully slide an opening pick underneath the camera cover and flash assembly to separate it from the motherboard cover.
  35. Nothing Phone (1) Charging Port Replacement, Fold over the camera cover and flash assembly: passo 35, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Fold over the camera cover and flash assembly: passo 35, immagine 2 di 2
    • Avoid straining the camera cover and flash assembly cable when folding it over.
    • Use a pair of tweezers to carefully fold the camera cover and flash assembly toward the battery.
  36. Nothing Phone (1) Charging Port Replacement, Unfasten the motherboard cover screws: passo 36, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the motherboard cover.
    • Return the camera cover and flash assembly to its original position.
  37. Nothing Phone (1) Charging Port Replacement, Pry up the motherboard cover: passo 37, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Pry up the motherboard cover: passo 37, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Pry up the motherboard cover: passo 37, immagine 3 di 3
    • Carefully fold the charging coil to the top edge of the phone to access the bottom edge of the motherboard cover.
    • Insert the flat end of a spudger underneath the bottom right edge of the motherboard cover.
    • Pry up with the spudger to release the motherboard cover from its clips.
    • Repeat the prying procedure for the bottom left edge of the motherboard cover.
  38. Nothing Phone (1) Charging Port Replacement, Remove the LED glyph assembly: passo 38, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the LED glyph assembly: passo 38, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the LED glyph assembly: passo 38, immagine 3 di 3
    • Remove the LED glyph assembly.
  39. Nothing Phone (1) Charging Port Replacement, Disconnect the battery cable: passo 39, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Disconnect the battery cable: passo 39, immagine 2 di 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  40. Nothing Phone (1) Charging Port Replacement, Peel off the battery pull-tab: passo 40, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Peel off the battery pull-tab: passo 40, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Peel off the battery pull-tab: passo 40, immagine 3 di 3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause fire.
    • Use a pair of blunt nose tweezers or a clean fingernail to peel the pull-tab labeled with an arrow off the battery.
    • Use the blunt nose tweezers to peel off remaining pieces of the pull-tab from the left battery edge.
  41. Nothing Phone (1) Charging Port Replacement, Loosen the battery adhesive: passo 41, immagine 1 di 1
    • The battery adhesive of the Nothing Phone (1) is very strong and loosening it beforehand eases the battery removal procedure and prevents damaging the cables running underneath.
    • Apply a heated iOpener to the screen to loosen the battery adhesive. Apply the iOpener for at least 2 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  42. Nothing Phone (1) Charging Port Replacement, Lift the battery: passo 42, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Lift the battery: passo 42, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Lift the battery: passo 42, immagine 3 di 3
    • Grab the pull-tab and pull up on the adhesive strip to lift the battery out of its recess and swing it up to an upright position.
  43. Nothing Phone (1) Charging Port Replacement, Remove the battery: passo 43, immagine 1 di 1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
  44. Nothing Phone (1) Charging Port Replacement, Unfasten the loudspeaker screws: passo 44, immagine 1 di 1
    • Remove the two screws securing the loudspeaker:
    • One 4.2 mm-long Phillips screw
    • One 4.2 mm-long Torx T5 screw
  45. Nothing Phone (1) Charging Port Replacement, Remove the loudspeaker: passo 45, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the loudspeaker: passo 45, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the loudspeaker: passo 45, immagine 3 di 3
    • Insert an spudger underneath the top edge of the loudspeaker.
    • Use your spudger to pry up the loudspeaker.
    • Use your fingers or a pair of tweezers to remove the loudspeaker.
  46. Nothing Phone (1) Charging Port Replacement, Disconnect the fingerprint reader: passo 46, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Disconnect the fingerprint reader: passo 46, immagine 2 di 2
    • Use a spudger to disconnect the fingerprint reader cable by prying the connector straight up from its socket.
  47. Nothing Phone (1) Charging Port Replacement, Disconnect the black antenna cable: passo 47, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Disconnect the black antenna cable: passo 47, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Disconnect the black antenna cable: passo 47, immagine 3 di 3
    • Slide a pair of tweezers under the black coaxial cable until they're snug against the metal connector.
    • Disconnect the black coaxial cable by prying it straight up from the daughterboard.
    • Use your tweezers to carefully loosen the cable from its routing on the daughterboard and bend it to the side.
  48. Nothing Phone (1) Charging Port Replacement, Disconnect the white antenna cable: passo 48, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Disconnect the white antenna cable: passo 48, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Disconnect the white antenna cable: passo 48, immagine 3 di 3
    • Slide a pair of tweezers under the white coaxial cable until they're snug against the metal connector.
    • Disconnect the white coaxial cable by prying it straight up from the daughterboard.
  49. Nothing Phone (1) Charging Port Replacement, Remove the SIM card tray: passo 49, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the SIM card tray: passo 49, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the SIM card tray: passo 49, immagine 3 di 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  50. Nothing Phone (1) Charging Port Replacement, Unfasten the daughterboard screw: passo 50, immagine 1 di 1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw securing the daughterboard.
  51. Nothing Phone (1) Charging Port Replacement, Remove the daughterboard: passo 51, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the daughterboard: passo 51, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the daughterboard: passo 51, immagine 3 di 3
    • Insert the pointed end of a spudger underneath the top edge of the daughterboard.
    • Use your spudger to pry up the daughterboard.
    • Use a pair of tweezers of your fingers to carefully remove the daughterboard.
  52. Nothing Phone (1) Charging Port Replacement, Disconnect the charging port cable: passo 52, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Disconnect the charging port cable: passo 52, immagine 2 di 2
    • Use a spudger to disconnect the charging port cable from the motherboard by prying the connector straight up from its socket.
  53. Nothing Phone (1) Charging Port Replacement, Separate the charging port cable: passo 53, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Separate the charging port cable: passo 53, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Separate the charging port cable: passo 53, immagine 3 di 3
    • Slide an opening pick underneath the top end of the charging port cable.
    • Slide your opening pick along the charging port cable to separate it from the midframe.
  54. Nothing Phone (1) Charging Port Replacement, Free the charging port cable: passo 54, immagine 1 di 2 Nothing Phone (1) Charging Port Replacement, Free the charging port cable: passo 54, immagine 2 di 2
    • Use a pair of tweezers or your fingers to carefully peel the black foam tape off the charging port cable.
    • There's no need to remove the tape all the way and you can reuse it during reassembly.
  55. Nothing Phone (1) Charging Port Replacement, Remove the charging port: passo 55, immagine 1 di 3 Nothing Phone (1) Charging Port Replacement, Remove the charging port: passo 55, immagine 2 di 3 Nothing Phone (1) Charging Port Replacement, Remove the charging port: passo 55, immagine 3 di 3
    • Use a pair of tweezers or your fingers to carefully lift the charging port out of its recess.
    • Remove the charging port.
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate a newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Altre 6 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
118 Membri
19.418 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 85
Ultimi 30 Giorni: 388
Tutti i Tempi: 10,440
