Salta al contenuto principale
Nintendo Wii U Button Replacement
Emily Vasquez
Emily Vasquez e 2 altri collaboratori
Ultimo aggiornamento il 10 giu 2021
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
Use this replacement guide for step-by-step instruction on how to replace the power and accompanying buttons on the Wii U console's front face panel.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  • Phillips #1 Screwdriver
  • Y1 Tri-point Screwdriver
    Y1 Tri‑point Screwdriver
Mostra di più…
  1. Nintendo Wii U Button Replacement, Button Replacement: passo 1, immagine 1 di 2 Nintendo Wii U Button Replacement, Button Replacement: passo 1, immagine 2 di 2
    • You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
    • Use a spudger to remove the stickers if it is difficult to peel off with your fingers.
  2. Nintendo Wii U Button Replacement: passo 2, immagine 1 di 1
    • Remove the five Phillips #0 screws.
    • Remove the four Tri-Wing Y1 screws.
    Looks like one of the screws labelled as tri-wing here is actually a phillips.
    CPR Stadiumvillage - Replica
  3. Nintendo Wii U Button Replacement: passo 3, immagine 1 di 2 Nintendo Wii U Button Replacement: passo 3, immagine 2 di 2
    • Remove the CMOS battery door on the left side of the console.
    • Once the door is removed, remove the three Phillips #0 screws.
    Looks like these are Y1 screws
  4. Nintendo Wii U Button Replacement: passo 4, immagine 1 di 3 Nintendo Wii U Button Replacement: passo 4, immagine 2 di 3 Nintendo Wii U Button Replacement: passo 4, immagine 3 di 3
    • Gently pry off the top lid of the Wii U.
  5. Nintendo Wii U Button Replacement: passo 5, immagine 1 di 3 Nintendo Wii U Button Replacement: passo 5, immagine 2 di 3 Nintendo Wii U Button Replacement: passo 5, immagine 3 di 3
    • Rotate the device so that the front plate is facing you.
    • Remove the two Phillips #1 screws.
    The one on the left was so tight it stripped extremely easily and won’t even budge when I have a good grip on it.
    Jake - Replica
  6. Nintendo Wii U Button Replacement: passo 6, immagine 1 di 3 Nintendo Wii U Button Replacement: passo 6, immagine 2 di 3 Nintendo Wii U Button Replacement: passo 6, immagine 3 di 3
    • Remove the ribbon cable and separate the front plate from the main console.
  7. Nintendo Wii U Button Replacement: passo 7, immagine 1 di 1
    • Remove the three Phillips #1 screws.
  8. Nintendo Wii U Button Replacement: passo 8, immagine 1 di 1
    • Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
  9. Nintendo Wii U Button Replacement: passo 9, immagine 1 di 1
    • Remove the desired button(s).
Conclusione
USF Tampa, Team 1-2, Leahy Spring 2016 Membro di USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
3 Membri
15 Guide realizzate
1Commento della guida
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
Lugi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 88
Tutti i Tempi: 5,355
